foglights
foglights
foggies stopped working. fuses and bulbs are fine but this seems abit suspect!(back of the foglight switch)
what caused that? and is it the culprit?
Re: foglights
Known issue. You will need to put a relay for that switch. Check the DIY section, there's a guide for it. :)
Re: foglights
And youll need a new switch as yours will now be burnt out
    Re: foglights
    dstocks wrote:And youll need a new switch as yours will now be burnt out
    Oh yes forgot to add that :D
    Retsub
    Re: foglights
    Post by Retsub »
    Has anyone had any success in replacing the light inside the fog light switch?
    it seems that the only what is to pull the whole damn switch apart.
    I want to put LED in there so i never need to do it again
    4. 02 Prado V6 (Wife's Car)
    Re: foglights
    Didn't even know if it had a light?
    Re: foglights
    I don't recall it having one. Unless the GR's and GPX's have them in it.
    Re: foglights
    There isn't a light
    Re: foglights
    Actually there is..... its a very small bulb.
    I've opened up 3 fog light switches so far and all have had the bulb burnt out, probably for the same reason the switch melts.
    Re: foglights
    How big is the bulb?
    Must replace!
    Re: foglights
    Re: foglights
    Omg!! I need to replace it!
    Retsub
    Re: foglights
    Post by Retsub »
    Thats the little F%#ker
    i do believe the antenna switch has one also.
    ive been searching the net for LEDs that may fit but have not found anything yet.
    the problem is the resistor and diode that needs to fit in as well because its 12volt.
    Re: foglights
    Jaycar have them, if they're the same as the dash lights.
    Re: foglights
    They aren't the same as dash bulbs. The switch has two pins, the bulb has two legs that twist around the brown rubber holder. You need a very low profile led, you may have problems with LEDs that have an external resistor.
    Re: foglights
    Vectose wrote:They aren't the same as dash bulbs. The switch has two pins, the bulb has two legs that twist around the brown rubber holder. You need a very low profile led, you may have problems with LEDs that have an external resistor.
    You could install the LED in the switch by itself, and cut the wire behind the switch and solder the resistor there. ;)
    Or use a SMD resistor.
    Re: foglights
    Okay now its sounding like too much effort lol
    Re: foglights
    :geny:
    Re: foglights
    :hmm: :hmm: :hmm: :hmm: :hmm: :hmm: :hmm: :hmm:
