needing some engine mounts for 95 GR
North and south ( front and back )
needs to be posted to 4209 or can pickup around gold coast to sunshine coast qld areas
thankyou
WTB Engine Mounts
- sly_industries
Re: WTB Engine Mounts
You can buy the inserts new if you like for about $115 bucks. Just need to get them pressed into your existing housings.
http://www.meek.com.au/index.php?act=vi ... ductId=250
http://www.meek.com.au/index.php?act=vi ... ductId=256
- spetz
So Evo 4-6 front and Evo 1-3 rear mounts are a direct fit?
Would the whole mount work or just the insert?
Just the insert.spetz wrote:So Evo 4-6 front and Evo 1-3 rear mounts are a direct fit?
- spetz
Good stuff Bennoz.
How does the car feel with those mounts?
Vibrations etc?
Vibrations etc?
Yeah, its a bit stiffer, bit more vibration, but certainly not uncomfortable. They're the proper MH90 hardness Evo spec rubber.spetz wrote:Good stuff Bennoz.
Vibrations etc?
I recently did the top mounts in them too, no complaints.
- spetz
To be honest I don't think top mounts make such a big difference in ride quality. Maybe only in extreme spring/damper rates will it be immediately noticeable.
I went from Fulcrum coilovers and stock top mounts to Tein SS coilovers which had front and rear top mounts and the ride was very comfortable. More so than the Fulcrum coilovers and OEM top mounts the Teins replaced
Lol, I'm talking about top engine mounts..
- spetz
Oh I see
They wouldn't have made much difference though I assume?
