47 Degrees
47 Degrees
Its 47 Degrees outside......
- Supplanter
- mattman
- bjk
- Totes
Re: 47 Degrees
More importantly, what's the temperature inside?
Re: 47 Degrees
17 here.... Had a high of 24... so almost half yours.
Re: 47 Degrees
No Aircon.........More importantly, what's the temperature inside?
- spetz
Re: 47 Degrees
I'm so glad I'm on the northern hemisphere, enjoying a delightfully cool winter
I didn't think it would get that hot in Australia?
When I was in Canberra summers were hot, but not overly hot and somewhat short lasting
Re: 47 Degrees
Canberra wasnt far short of that temperature yesterday. Im only an hour and a half from Canberra(work there) and its usually hotter than here.
- shadowarrior
- Tightarse
Re: 47 Degrees
Hope you have a nice swimming pool/water hole/lake to dip in. I would have gone crazy in that heat without an AC :\dstocks wrote:No Aircon.........More importantly, what's the temperature inside?Too much power draw for solar.
Re: 47 Degrees
Yep, no AC at my joint either..
Hope all is well down there in this heat Dwayne!
- topgun
Re: 47 Degrees
Not even telling you what temperature we have!! You will all piss yourself!!
- aza013
- NSW Coordinator
Re: 47 Degrees
I have A/C in the house and now in the man caveDaniel2019 wrote:Yep, no AC at my joint either..
Re: 47 Degrees
I have a pissy portable AC in my house and it brought the outside temp of 47 down to inside temp of 41
Re: 47 Degrees
Meanwhile, my fan just blew 47 degree air around my room and lowered it to probably 46.9...PHIL069 wrote:I have a pissy portable AC in my house and it brought the outside temp of 47 down to inside temp of 41
