Thermo fans
blade20034
Thermo fans
Post by blade20034 »
Hey guys i have a 1995 fto 2.0 v6 and the thermos seem the stop working i tested them on the batt and they work looked athe fuse box and i would not have clue where to start as it is in Japanese :? any other ideas why there not working?
Re: Thermo fans
blade20034
Re: Thermo fans
Thank you so much now to test this fuse and go from there :/
blade20034
Re: Thermo fans
fuse looks fine is there some sore of temp that these fans kick in at like a sensor thats could be lose?
Jase726
Re: Thermo fans
Post by Jase726 »
I know the smaller one has something to do with your air con pressure. The larger one should be controlled by a sensor / computer. I'm sure someone can verify / correct me on the above.
Re: Thermo fans
Thermo/radiator fan is on the passenger side of the FTO. It is operated by the ECU. The ECU gets it's engine temp readings via the Engine Coolant Temp Sensor.
So the Engine coolant temp sensor reads the engine/coolant temp, sends the readings to the ECU, the ECU then turns the fan on/off as required.
The ECU sends the fan on/off signal through the Radiator Fan Relay (as pictured), the fan receives battery power through a fusible link (Fuse #13 as pictured).
Some more info...
Engine coolant temp sensor 02.jpg (72.34 KiB) Viewed 266 times
FUSE #13
FUSE #13
blade20034
Re: Thermo fans
Thank you guys
