Forums getting slower?
Past couple of days ive noticed that it sometimes takes forever to load the FTOaus forums (and no, its not my internet EVERYTHING else loads instantly etc)
Is anyone else getting this from time to time?
Re: Forums getting slower?
Yep.
Given though, my internet has been really up and down. My net speed fluctuates from <1mb/s, barely even able to sign in on PS3 to up to 10mb/s. It also turns off and on occasionally and doesnt work when someone uses the microwave (seriously).
But yeah, Ive noticed that sometimes it also doesnt load properly - white boxes where the mitsubishi logos and the red banner car and homepage quick link on the top left.
No problems here, I am still using the old forum though.
No problems here either. Using the old design or Tapatalk.
Using the old forum too. It doesnt happen often, maybe once every few days ill refresh it in a few minutes and its fine again. Just wondering if its on my end oe the server end.
- Supplanter
- Kustom
Taz wrote:Just wondering if its on my end oe the server end.
Taz wrote:and no, its not my internet EVERYTHING else loads instantly etc
FLOL.Kustom wrote:Taz wrote:Just wondering if its on my end oe the server end.Taz wrote:and no, its not my internet EVERYTHING else loads instantly etc
Have any of you seen the weather in tornado alley at the moment? That's where the server is. Under 12 foot of snow.
Im referring to software on my end dickhead, the first was referring to my connection.Kustom wrote:Taz wrote:Just wondering if its on my end oe the server end.Taz wrote:and no, its not my internet EVERYTHING else loads instantly etc
I wonder how many times ill genuinely feel the need to use this picture on you
- 384916_480147282008352_1313138503_n.jpg (33.3 KiB) Viewed 620 times
Hook, line & sinker.
Bennoz wrote:Hook, line & sinker.
- kiz
- SA Coordinator
EFABennoz wrote:Hookers, lines & sphincter.
1998 Mitsubishi FTO GPVR AERO
I get it here occasionally as well..
Sounds like you are getting interference on your WiFi.Daniel2019 wrote: Given though, my internet has been really up and down. My net speed fluctuates from <1mb/s, barely even able to sign in on PS3 to up to 10mb/s. It also turns off and on occasionally and doesnt work when someone uses the microwave (seriously).
Try changing the WiFi channel in your router settings.
- -Nighthawk-
The forums have been rock-solid for me lately (I'm also using the new version, which is slightly faster).
I have just had a major issue getting the forum to work. (about 10 min of blank pages and errors)
Other web pages loading fast.
Info received...
1st message on IE...
General Error
SQL ERROR [ mysqli ]
User ftoaustr_php1 already has more than 'max_user_connections' active connections [1203]
An sql error occurred while fetching this page. Please contact an administrator if this problem persists
2nd message on IE...
[an error occurred while processing this directive]
Forum stats...
In total there are 7 users online :: 4 registered, 0 hidden and 3 guests
It is currently Mon Jan 28, 2013 10:48 pm
Info received...
General Error
Forum stats...
There's your problem.PHIL069 wrote:IE
I was just about to post the same thingVectose wrote:There's your problem.PHIL069 wrote:IE
- Supplanter
I like the way it points to your own comment.Taz wrote:Im referring to software on my end dickhead, the first was referring to my connection.Kustom wrote:Taz wrote:Just wondering if its on my end oe the server end.Taz wrote:and no, its not my internet EVERYTHING else loads instantly etc
