Non-Mivec engine parts for sale
- Dras
After having done a MIVEC engine conversion, I have my old engine taking up room in my garage. It has done 180,000kms and the valve stem seals leak oil. Other than that, it is in quite good condition.
I will be striping it down, because I can, and was wondering if anyone wants anything?
The components on offer include:
Red Magnecor 8.5mm ignition leads (approx 10,000km old)
Alternator (approx 10,000km old)
Injectors (went straight into an air tight bag when they were removed from my car)
GR engine cover in good condition
Upper intake manifold
Coil packs
Tappets (approx 10,000km old and quite)
GR Rocker covers
GR cams with gears
GR heads
Block
Pistons
Crank
Make me an offer.
Coil packs
GR Rocker covers
GR cams with gears
GR heads
Block
Pistons
Crank
Make me an offer.
Re: Non-Mivec engine parts for sale
Lawso might want the tappets
Can the leads be used on a mivec? if so dibs
- Dras
NopeSahin wrote:Can the leads be used on a mivec? if so dibs
- Lawso
- Penis Fingers
i'll let you know dras, i'm looking into doing some work to my car at the moment, might be able to take a lot off your hands. will get back to you soon
BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETS BUY THE TAPPETSLawso wrote:i'll let you know dras, i'm looking into doing some work to my car at the moment, might be able to take a lot off your hands. will get back to you soon
- fraz91
- Hair-do
^^ What he said.
Im interested in the manifold and TB.
- Lawso
- Penis Fingers
will be in contact mate. sometime soon hopefully. i've got a little something up my sleeve
Lawso wrote:i've got a little something up my sleeve
- Dras
Let me know what you are after so that I can put it aside.Lawso wrote:will be in contact mate. sometime soon hopefully. i've got a little something up my sleeve
- Lawso
- Penis Fingers
- Dras
Probably hoping to get rid of it in about a month or so.
This would be good opportunity to make a coffee table .
- Lawso
- Penis Fingers
Conrods/pistons still there ?If so, what's the condition like ?
