Manual convert wiring
ftonoob
Post by ftonoob »
Going from 5sp tip to 5sp manual.
How do I defeat neutral safety switch?
How to install clutch switch and get reverse light to work?
Thanks in advance.
Re: Manual convert wiring
For the neutral safety you will need to join the two bigger wires (on the large black plug on auto loom) together, it's the black wire with yellow stripe and black with red stripe.
For the reverse sensor, wire in the red with blue stripe and black with yellow stripe (small wires) - they're next to each other on the auto plug.
What do you mean by clutch switch?
ftonoob
Post by ftonoob »
Would I be able to start the car with the clutch down?
Should be able to start it with clutch up or down - doesn't matter. There's no clutch switch.
fraz91
Hair-do
Post by fraz91 »
Only need a clutch switch if you're installing cruise control so that the engine doesn't rev its t!ts off when you change gear. ;)
You can install one if you want it as a safety feature though.
ftonoob
Post by ftonoob »
Ok. Can I get a guide to do the clutch switch?
ftonoob
Post by ftonoob »
What are my options for new flywheel bolts?
Dude. Go to a nut and bolt shop with your originals?
silverGPX wrote:Dude. Go to a nut and bolt shop with your originals?
This
Make sure u tell them what it for though as nuts and bolt have different grades wouldn't want the replacements to snap the heads off after putting it back together
ftonoob
Post by ftonoob »
Did that and no luck. Grade 8 bolts
ftonoob
Post by ftonoob »
Do the 6a12 and 6a13 share flywheel bolts?
The best person to answer that would be bennoz
YES they do
Yup, same same.
ftonoob
Post by ftonoob »
Good I'll have to hit mitsu for some bolts
ftonoob
Post by ftonoob »
http://www.camskill.co.uk/m3b0s12p8416/ ... E3A_2_0_V6
Would these work for my manual conversion?
ftonoob
Post by ftonoob »
Went arp for flywheel bolts from ford 2.0l zetec engine. The reverse light wires are on the same black connector as the neutral wire or is it on the connector leading to the gear selector assembly?
ftonoob
Post by ftonoob »
Gearbox is in, wastegate actuator is shifted and car is being put back together.
ftonoob
Post by ftonoob »
Thanks to all those who helped me out. Gearbox is in and working great. I have tons of room in the bay.
