Fto gpx manual gearbox
- Connor_1994
I have a fto gpx manual gearbox 5-speed.
In good condition needs a new clutch for install and a allover degrease
Oil in it is still clean
Have all sensors and pedals etc for manual conversion
$500 for gearbox ono we can work sonething out and include other parts
- Connor_1994
Re: Fto gpx manual gearbox
Picturs coming
- Connor_1994
Can you tell us the stamping number from the frontside of bellhousing?
- Shhtuart
And you'll snaffle it up if there's a sneaky LSD sitting in itBennoz wrote:Can you tell us the stamping number from the frontside of bellhousing?
Shhtuart wrote:And you'll snaffle it up if there's a sneaky LSD sitting in itBennoz wrote:Can you tell us the stamping number from the frontside of bellhousing?
I want a LSD
- JOA81
- Connor_1994
I believe the bearings are fine
And bennoz ill have a look tonorrow for you
And get u the stamping number
- Connor_1994
Hey bennoz sorry mate i was really busy helping my mate put his engine back in and havnt been home to my place
But we will be finished early tomorrow and ill get that stanp number for you then
S'ok mate, no hurry
- Connor_1994
The only number i could see today was this number behind the front mounting bracket the number is - F5M42
Is that the one your looking for or is there another one?
- rock_it
It is the W that came stock with LSD yeah??
- rock_it
Forget that.. Different series box.. You want to see..rock_it wrote:It is the W that came stock with LSD yeah??
F5M42 2-2R7A / AA5171
F5M42 2-2R7A / TT1471
F5M42 2-V7A6 / VA4906
I think the swcond set od numbers is car specific not gearbox type. My gpr has a different second set but the first matches up and its defs an lsd. So should be ok if the v7a6 matches up for a helical (and probably for the others) although this is my speculatiob so feel freeto ignore me haha
- Connor_1994
Where would i find the rest of those numbers?
I do believe mine came out with a lsd as standard, but i could be wrong
If the numbers are part of the gearbox like they are in the photos above then it can't be car specific.Taz wrote:I think the swcond set od numbers is car specific not gearbox type. My gpr has a different second set but the first matches up and its defs an lsd. So should be ok if the v7a6 matches up for a helical (and probably for the others) although this is my speculatiob so feel freeto ignore me haha
If they are painted on, or there is a plate or something attached then they could be car specific. They wouldnt change the mould for different numbers on every gearbox.
The numbers are stamped in on a little flat area of the box. I also believe the last set of numbers is a identification number, like a engine number.
The more you know.Vectose wrote:The numbers are stamped in on a little flat area of the box. I also believe the last set of numbers is a identification number, like a engine number.
- HeRo
Are the manual gearbox's all the same for the GR, GPX, GPvR aside from the LSD aspect?
