Has 152XXX on the clock.
Will be a complete assembled block, minus the sump and leads/coils. (leads/coils can be left on if something is worked out but i need the sump for the other fto) Perfect if yours is goneskies and your sump and leads/coils are still good.
Timing belt and water pump replaces at 100km. Never missed a beat in the 30km ive had it. No tappet noise, always filled with 5w30 castrol edge fully synth. Iridium spark plugs JUST replaced at 150 (major service done) Only minus is it could use some tappet cover gaskets - only a drip every now and then seems to seep through so i never bothered to replace them when i noticed - always retained the oil between service intervals - no drips left on driveway etc
Asking 500 ono, located in brissy but can ship at buyers expense (not sure how much it will be as i refuse to use EGO couriers anymore
