Spark plug wear and tear
NextLevel
Post by NextLevel »
Does this look like a normal wear?
Re: Spark plug wear and tear
http://www.aa1car.com/library/reading_spark_plugs.jpg
Youll be able to better match it up with one of those listed ;)
Well it's not worn, it's coated with a build up of either burnt coolant or combustion ash or unburnt fuel additive.
How long does it take to build up?
What fuel are you using, brand and type and octane level?
Are you adding anything to your fuel?
Is your FTO using/loosing coolant or oil?
What colour is the inside of your exhaust tip?
Does your FTO blow smoke or water out of the exhaust? If so what colour?
Was your engine misfiring with those plugs installed?
Were all your plugs the same?
NextLevel
Post by NextLevel »
here is a short video of my car at idle.
I am currently using Shell Vpower 98 Ron.
Using Nulon Octane Boost & Clean.
Oil and coolant have stayed pretty much at the same level in the 3 months i have had the car.
No color smoke is coming out of exhaust.
Car does not sound or feel like it's missing. car can stall after initial start up at idle when the car has been parked for a while time.
All plugs had similar brown soot and are in similar condition.
Not sure how long it takes to soot up, but will be replacing the plugs with new one soon.
NextLevel wrote:I am currently using Shell Vpower 98 Ron.
There's your problem. :lol:
NextLevel
Post by NextLevel »
Ok, i'll try BP once the tank hit toward E.
cheers
NextLevel
Post by NextLevel »
Vectose, does my idle sound normal to you?
Idle sounds good.
I prefer to use Caltex Vortex 98, I have had troubles with shell fuel in a few different vehicles.
How often do you use octane boost, if you put it in every tank than that could be your ash buildup cause.
NextLevel wrote:Soot
:lol: i laugh everytime i read that word
I run only BP Ultimate 98, but that's because BP is the only place here that sells 98 :(
Caltex 98, cos the refinery is like 10kms from work :)
I used to manage a 24/7 Shell Roadhouse and because of that I always ran the PULP 98 octane Shell fuel (Advantage of not having to pay for fuel at that stage). Since moving to Adelaide I've been using BP Ultimate 98 and my car is more responsive and I get far better fuel economy :?
I use whatever servo is nearby - because 9 times out of 10, I'm running on fumes :cheers:
this ^ have to get whatever is closet nowdays haha
I use shell and don't get that build up. What plug is that? Sure its the right one?
