Wheel hub studs
Wheel hub studs
Anyone know the size, or a part number?
I figure they are Mitsu generic, the likes of Magnas etc would be the same as same thread....?
Going to change the rears, not paying $600 just for the fact of fixing hack-sawed hub studs.
Re: Wheel hub studs
I know they're a 1.5 pitch thread... and that I have a bucket load of them at home
HTH
HTH
Re: Wheel hub studs
Hope That HelpsAstron_Boy wrote:What is HTH.....
I'm not Googling another fkn Gen Y thing...
Re: Wheel hub studs
.................................................................. hmm.Bennoz wrote:Hope That HelpsAstron_Boy wrote:What is HTH.....
Yeah, seem to be pretty much generic studs then.
Just the fun of removing the hub, removing the studs and putting the new bastards in.
Re: Wheel hub studs
You don't have to remove the hub, just belt them out with a lump hammer. Push new ones in as far as you can, then wind a nut all the way up it & watch it pull through to the correct spot as you tighten.
Oh & part number is MB911495. But yes, they are a generic thing.
HTH
HTH
Re: Wheel hub studs
Ahh k, will try that.Bennoz wrote:You don't have to remove the hub, just belt them out with a lump hammer. Push new ones in as far as you can, then wind a nut all the way up it & watch it pull through to the correct spot as you tighten.
Last time I did hub studs was my old Hilux where there was no option but to remove the entire assembly due to the locker.
And yes, that did help.
- Supplanter
Re: Wheel hub studs
Go Lick a Hunstman's Fanny?Astron_Boy wrote:Lateral thinking.Supplanter wrote:GLHF
Good luck, have fun?
- rock_it
Re: Wheel hub studs
Got Lube Huge Fella?Bennoz wrote:Go Lick a Hunstman's Fanny?Astron_Boy wrote:Lateral thinking.Supplanter wrote:GLHF
Re: Wheel hub studs
Girls Love Hot FTO's
or
God Loathes Horrible FTO's
or
Re: Wheel hub studs
Astron_Boy wrote:.................................................................. hmm.The irony.
Twice in one thread Astron...
- payaya
Re: Wheel hub studs
You can get them from Repco for 5 bucks!
