Why storing liquids in the boot is a bad idea...
Derp.
I had a full bottle of new semi synthetic castrol magnatec and a half full bottle of coolant sitting behind the sway bar in the boot.
In order to stop them for moving I thought it would be a great idea to secure them with a spare car battery that I hadn't had the chance of chucking into a neighbors bin yet.
So long story short there was all those liquids over the boot, under the rear seats and a small pool in the rear foot well. The worst part is that the seats are made of foam :(
THIS ISN'T THE POINT OF THE THREAD.
There was a high pitch whine coming from my exhaust that I took as an exhaust leak. After I removed the back seats to clean the said oil it became louder and I realised it was coming from the fuel tank cover. I have come to the conclusion that my unsmooth revs and high pitch whine are the result of a failing fuel pump. I've had the habit of running the tank down to empty before refueling (#studentlyf) and I read this is bad for these fuel pumps.
Re: Why storing liquids in the boot is a bad idea...
Hang on.
So, is what you said above
Shhtuart wrote:THIS ISN'T THE POINT OF THE THREAD.
Not the point, or below.
If above, then the title is contradictory to the sentence beneath that line. :lol:
:troll:
Oh, and yeah, sucks, next time secure them in a small freezer bag which prevents spillage. Great tip I was given years ago.
Re: the pump, I always run mine down, so....
And given most FTO owners I would say they would too, but for a different reasons. ;)
Best not run it down too low (if you have a choice) or you suck the crap off the bottom of the tank. This will clog the fuel filter at the very least. And most of us know thats a pain in the butt to change over. Case in point. I tipped the fuel out of one of the wrecks I had into a jerry can for the mower (why not use it right). Half way through mowing for the bonfire this year, the mower died. Clogged fuel filter.
    That reminds me, I need to change our fuel filter. :(
    NOOOOOOOOOOOOOOO!
    Astron_Boy wrote:That reminds me, I need to change our fuel filter
    I'll undercut bennoz and do it for a case of carlton dry.
    That'd be f**king epic if you could.
    But my free time is next to Jack Daniels currently. :lol:
    current priority.
    Build garage
    Install hoist.
    I'll do it for a six pack. :lol:
    Vectose wrote:I'll do it for a six pack. :lol:
    Screw that, I'm out. I 'aint no illegal immigrant mexican.
    :lol: It isn't that hard of a job. Half hour.
    Vectose wrote::lol: It isn't that hard of a job. Half hour.
    Just BS on your shoulders, neck and back. :?
    Gen Y don't have those problems. :cheeky:
    It's 4 bolts lol
    Walhbro is only $120 delivered so that's alright. Can you clean the tank out from the top when you are changing the pump or is that a drop the tank out job?
    P.S. YOU ALL SUCK AT STAYING ON TOPIC :lol:
    Shhtuart wrote:Walhbro is only $120 delivered so that's alright. Can you clean the tank out from the top when you are changing the pump or is that a drop the tank out job?
    What was the topic?
    You never explained. :P
    Best to drop the tank to clean it.
    Just stick a hose in it and turn the tap on :troll:
    Sahin wrote:Just stick a hose in it and turn the tap on :troll:
    Turn the engine on once you've filled it to clean the lines out, etc? :troll:
    Add a bottle of dishwashing detergent as well.
    This!^^^^ he knows
    FTO Australia
    f**king Trolls Organisation Australia!
