viewtopic.php?f=18&t=24621
These are currently at my property on the South Coast (NSW), but can deliver to Canberra or freight (at buyers expense).
Here is how they look painted (Will try and get a better pic soon):
My rear bar didn't line up properly on the rear. Front Ts bar was no issue what-so-ever. Between that and my fiberglass bonnet not lining up 100% i'm over aftermarket body kitsVectose wrote:Rear bar was simple to fit compared to fenders. The fenders do require a bit of fiddling to get aligned properly.
Sounds like you are a perfectionist like me (most haven't worried about those bits). I spent the extra time myself building in the original metal support brackets into the sides of my rear bar. They weren't able to do this as a part of the mould as its on the wrong side of the bar. I did this by attaching the brackets on each side to the car and then from memory putting dabs of reinforced auto putty on the points where it should attach to the bar. I then quickly fitted the bar and lent something heavy against the outside of the bar until it was perfect. When set, I removed bar with metal panels attached and added some more reinforced putty to make sure they didn't come off.Now that pulls the sides in that little bit extra.The actual bar fits perfect but between the tail lights and the rear wheel arch area is sits out a bit.
Cheers, I did wonder about the metal support brackets on the side not being there. I will look into adding them because it's similar to what I was going to do anyways. I think I've still got my brackets at VipFTO's place with my facelift bars somewhere hahadstocks wrote:Sounds like you are a perfectionist like me (most haven't worried about those bits). I spent the extra time myself building in the original metal support brackets into the sides of my rear bar. They weren't able to do this as a part of the mould as its on the wrong side of the bar. I did this by attaching the brackets on each side to the car and then from memory putting dabs of reinforced auto putty on the points where it should attach to the bar. I then quickly fitted the bar and lent something heavy against the outside of the bar until it was perfect. When set, I removed bar with metal panels attached and added some more reinforced putty to make sure they didn't come off.Now that pulls the sides in that little bit extra.The actual bar fits perfect but between the tail lights and the rear wheel arch area is sits out a bit.
With the bit between the lights, I used masking tape to protect the lights and fitted the rear bar. I then used auto putty to perfectly match the bar to the taillights. I did the same thing with the lip between the rear quarters and the top of each side of the bar.
Unfortunately, what you are encountering is the limitations of fibreglass mounds. They can only really do one side. Any brackets and things on the back have to be manually made. As a result, they only tend to do the ones that are absolutely necessary to keep the cost down. As a result, there is practically always preparation work required to get a "perfect fit". With the rear bar, the bits that could have been better in the mould are where the quarters meet the the tops of the bar. The rest was always going to be something that had to be done after.
Oh i'm sorry, is it taking up the space where you want to do my turbo build onvipfto wrote:yip taken up precious garage space lol
