5 speed gear box cv shaft issue
MOR31
Post by MOR31 »
so i have my 6a13tt bolted to a fto 5 speed box with lsd, when i put it all together i noticed the gearbox leaking, thinking it was the seal, replaced that to find it leaked straight out again.it sitting like this
managed to get my hands on another, thanks to TAZ.
this is the one i borrowed, its to thick to even fit into the box so its obviously not the one i need. its almost as if it need to be 10mm shorter in between the slpines and where the seal sits
this is the one i have, it fits in and locks in perfect but still sits out away from the seal
any help is appreciated as i need the car back on the road asap
Re: 5 speed gear box cv shaft issue
Yep this is the same problem as the guy from the Netherlands was having.You need the right driveshaft end (and currently you dont have it). Check this thread out for more info:
http://ftoaustralia.com/v3/viewtopic.php?f=21&t=27648
    dstocks wrote:Yep this is the same problem as the guy from the Netherlands was having.You need the right driveshaft end (and currently you dont have it). Check this thread out for more info:
    Just going on a bit of deduction however.
    Taz had a vr which had LSD, therefore the shaft he gave morel should be correct.
    So... What's the go there.
    From memory the LSD were a stumpy shaft compared to the open diff...
    From memory the viscous LSD were a stumpy shaft compared to the open diff...
    EFA
    That's the thread I was trying to find!
    MOR31
    Post by MOR31 »
    Cheers. That thread ended a little weird.
    Any one got some part numbers for the cup or even the whole shaft?
    Its finally been sorted! :cheers:
    went to a cv joint, managed to get the right cv BORROWED (as the guy didnt want to sell his only one!??) and took that to panelhouse in slacks creek (the same place he went to a week before that said they didnt have any) and wouldnt you know it, showed up with the reference - boss comes out and says yea - should have one of them.
    an hour later the shaft was cleaned up and in the car - ready for a nice drive home 8)
    And Bennoz....i must say - this thing is stupidly fast much like your red rocket. Would give it a good match at least :lol:
    flateric
    Post by flateric »
    wow ! good to see that this issue has been resolved 8O . i have replaced my LSD 4speed gearbox by a non-LSD 4 speed and running like new! i'm going to take the LSD out of the box so if anyone is interested.
    if it doesn't brake just hit the gas
    Audi A6 avant 1.9 tdi - 175HP
    Honda CRX 1986 - 130 HP
    Mitsubishi FTO 1996 - 200HP
