Failed my WOF :(
Failed my WOF :(
Hey all,
So my FTO just failed it's WOF inspection on the rear trailing arm bushses, and the PS Belt.
Does anybody have the part numbers for the belt, and/or the part numbers for the nolothane bushes?
I did a quick search, but couldn't find the part numbers.
But it was only a quick search, as I'm in a class atm :p
Cheers,
Braydon.
edit: if I'm not mistaken, I believe MR102063 is for the standard trailing arm bushes?
Cheers,
Braydon.
Re: Failed my WOF :(
Cheers Taz!
Now, lets hope I can get them locally, my car's now illegal to drive except for getting the parts.....
Damn WOFs, although I have been planning on doing the bushes anyway.
And the PS belt is slowly eating itself away, it's already down to three ribs...
Or offset Nolathane equivalent if you're that way inclined..
http://www.nolathane.com.au/product_det ... mber=46241
What is the difference exactly?
The offset is to push the arms back further, essentially elongating your wheel base. Which is supposed to improve handling.
Ahh, cheers, I may try for those locally then :p
So, about $205 for new bushings and belt, $153 for the bushings and $52 for the belt.
Does that sound about right?
Just remember these are NZD...
f**king expensive. Even for NZ pesos
Welcome to Repco NZ
Should just move to Tassie.
Still overseas, but they accept our currency and local exchange.
Bribie Island was far enough 'Over Seas' for me when I lived there
What do u mean it pushes the arm back?
The hole in it is offset, much like your front control arm bushes that push the lower control arm out further - similar concept.silverGPX wrote:What do u mean it pushes the arm back?
So id have more potential of inner arch rub?
In this instance we are moving the hub assembly towards the rear of the car, not in or out. I was just using the front bush as an example for offset bushes.
You can see how it works here:
Cheers for picture. I was having a hard time visualizing. Would this affect camber or toe?
NZ Dollars
You don't get much for SHEEP POO these days
4. 02 Prado V6 (Wife's Car)
So we got them out last night, now i'v just got to take them to the mchanic so he can put the new ones in, then I will finish them off after work tonight...
- shadowarrior
- Tightarse
Oh wow. Needed to fix my rear trailing arm bush, might do it all together for better handling then.
Is the work labour intensive? (Thinking on costs to get it installed via a mechanic)
