magna bits?
- okamitengu
magna bits?
i have heard i can rape magnas for parts... can anyone add to this list, or IS this the entirety of magna models i can strip?
throttle body.. te-tw magna 6g72/74
brake calipers: .. ?
shock absorber mounts?
any other parts? im interested to see (: search didnt help for shock absorber mounts
- spetz
Re: magna bits?
TB fits
Top mounts I read fit
Brake calipers, most are single pot so it would be a downgrade I think
I think maybe the knuckles fit allowing easy Evo Brembos to be fitted but no confirmation of this
Re: magna bits?
Did anyone ever confirm weather the throttle bottle is actually safe ?
I did the search, and there some talk of it running rich etc and could cause damage. .?
Re: magna bits?
Yeah runs heaps rich down low. On idle mine was like 17:1 A/Fs. Had to rejig my maps a bit. Up high it was ok, but I wouldn't be doing it if I didn't have an adjustable ECU.destinationtoby wrote:Did anyone ever confirm weather the throttle bottle is actually safe ?
Re: magna bits?
How big is the TBBennoz wrote:Yeah runs heaps rich down low. On idle mine was like 17:1 A/Fs. Had to rejig my maps a bit. Up high it was ok, but I wouldn't be doing it if I didn't have an adjustable ECU.destinationtoby wrote:Did anyone ever confirm weather the throttle bottle is actually safe ?
Re: magna bits?
So it's not the sorta thing I should do if I don't know what I'm doing apart from bolting straight and getting a small power gain?
Re: magna bits?
So best bet is to do the throttle body upgrade at the same time as installing a haltech etc..
Interdasting...
Interdasting...
Re: magna bits?
65mmsilverGPX wrote:How big is the TBBennoz wrote:Yeah runs heaps rich down low. On idle mine was like 17:1 A/Fs. Had to rejig my maps a bit. Up high it was ok, but I wouldn't be doing it if I didn't have an adjustable ECU.destinationtoby wrote:Did anyone ever confirm weather the throttle bottle is actually safe ?
Correct. Plus there's a bucketload of grinding to be done to the intake manifold to match it to 65mm as well.destinationtoby wrote:So it's not the sorta thing I should do if I don't know what I'm doing apart from bolting straight and getting a small power gain?
You could also do it at the same time you put your engine back togetherDaniel2019 wrote:So best bet is to do the throttle body upgrade at the same time as installing a haltech etc..
Interdasting...
- okamitengu
Re: magna bits?
so.. back to interchangeable parts?
i was already aware of the Throttle body!
derailment everywhere!
Re: magna bits?
What did you expect?
It's FTOAU after all!
Re: magna bits?
I think The magna has the same stud pattern, so should be able to fit some magna stockies on your fto
Re: magna bits?
Thats what I was going to do but an ECU upgrade/tune wont be done for a little while after its back together and I dont want it running like sh*t until then.Bennoz wrote:You could also do it at the same time you put your engine back together
- spetz
Re: magna bits?
Bennoz did you ever install a Magna TB on an FTO plenum or just the 6A13?
I remember RPW was saying that the FTO plenum needed additional metal welded on before grinding. Any truth to this?
Re: magna bits?
Just the 6A13. Shane001 did one to an FTO plenum on his racecar, all it needed was the mouth ground out, same as mine.spetz wrote:Bennoz did you ever install a Magna TB on an FTO plenum or just the 6A13?
Sorryokamitengu wrote:so.. back to interchangeable parts?
Brake calipers are different, but the disc rotors on the 3rd gens are the same as GPX (276mm)
Shocks are different, top mounts are same as FTO.
I'm pretty sure some of the engine mounts are similar too, but would have to go look at one to confirm.
Some of the interior is the same, the Verada has the same climate control head unit as FTO (non VR), Indicator assembly is also similar.
Re: magna bits?
I've used the little switch cover for the headlights stalk from a Magna as the markings had faded
- okamitengu
Re: magna bits?
where is my like button ..
im just gonna randomly like one of your facebook comments ben, its for this response.. remember that when it happens...
Re: magna bits?
I'll keep an eye out for itokamitengu wrote:where is my like button ..
Re: magna bits?
I have a 65mm Magna throttle body and a ground out FTO plenum..............sitting in my garage for use one day...........got it off of Akys...........Hmmmm, still need to give you $20 moar Akys, maybe next bonfie, if you show.Bennoz wrote:Just the 6A13. Shane001 did one to an FTO plenum on his racecar, all it needed was the mouth ground out, same as mine.
- vipfto
Re: magna bits?
done on mine even pre turbo just matched plenum inlet to suit easy mod had to fiddle bit with new TB as in just swap over water lines. even TPS is same, although could adjust A/F ratios too and does run rich at idle without ability to do so
Re: magna bits?
Oh yeah, I forgot about the water lines. I just swapped the whole cooling housing over from the original TB.vipfto wrote:spetz wrote:Bennoz did you ever install a Magna TB on an FTO plenum or just the 6A13?
