Help
Jase726
Help
Post by Jase726 »
3rd to 2nd at speed in my tip is nice and smooth. At slow speeds I'm getting a clunk. Is it transmission or shaft related. Thanks in advance.
Re: Help
Hows your auto transmission fluid looking? Replaced recently or old and crappy?
Jase726
Re: Help
Post by Jase726 »
To be completely honest I haven't checked for a while. I'll have a look at the DIY section and give it a service. It's been almost 50k since my major service.
Re: Help
Just check using the dipstick. It's on the passenger side of the engine bay kinda under your air filter.
Re: Help
Actually, if you havent changed it in a while, do it. Is often the cause of a clunky tip box.
    Jase726
    Re: Help
    Post by Jase726 »
    Thanks guys. I'll get on to it.
    Jase726
    Re: Help
    Post by Jase726 »
    So I had the tip hooked up and flushed. Oil and filter change resulting in super smooth shifts. It did cost $250 though. Not sure if this was expensive for the particular procedure but it did the trick.
    Re: Help
    Proper mechanic flush is the way to go.
    Re: Help
    Hmmm, while transmission fluid is expensive, I wouldnt have said it should have cost you that much. At leat it fixed the problem though.
