rims
viper-99
rims
Post by viper-99 »
what is the biggest size rims that can fit on a gp and with
Re: rims
24" with 11" wide mate cant't have tires on them though
Re: rims
Just buy a lift kit and put 35" muddies on there
Re: rims
Like this guy
Re: rims
Or some hectic camber to tuck em under
Re: rims
:lol: at both of those cars.
To answer the question, I think Tippin had 19 inch rims, probably pretty thin rubber though. Depends on a lot of factors. How much rubber do you want? Do you want to be modifying the fenders? (rolling/flaring) Are you lowered at all?
For the width 9 or 9.5 is the limit, depending again on the offset and size of tyre you use.
Re: rims
bjk wrote::lol: at both of those cars.
Pending what type of rubber you're talking about, Ultra thin rubber is designed to either give an awesome ride or a really bad one.
Re: rims
:(D):
Re: rims
:(D):
No :(D): needed here, I meant condoms.
In terms of wheels, 19 is about as big as you can go. But if youre any lower than stock height its highly likely you'll be scrubbing somewhere. 19s are pretty borderline. Go with a sensible sized set of 18s with lower profile tyres.
Re: rims
My exs FTO had 10.5 on the back
Re: rims
silverGPX wrote:My exs FTO had 10.5 on the back
Who? Taz?
Re: rims
:cheeky:
viper-99
Re: rims
Post by viper-99 »
i was looking at throwing on 17s or 18s with low profile tires and looking at lowering about 30mm after the new body kit goes on
Re: rims
I am running 17x8 with a +32 offset and a 215/45 tyre, lowered about 30mm.
I get slight rubbing on the inner guard on full lock.
Lawso
Penis Fingers
Re: rims
Post by Lawso »
Vectose wrote:I am running 17x8 with a +32 offset and a 215/45 tyre, lowered about 30mm.
if thats the case, i'm fucked with my rims :/ :lawso:
Re: rims
You may be okay. I consulted with Sahin, and he's running 235/45.
Re: rims
I'm running 18" x 9.5" +20 with 225/40
I used to know a guy running 20's on the back, "alekazam" on the forums. He had 18's on the front though i believe.
c3rbera
Re: rims
Post by c3rbera »
viper-99 wrote:i was looking at throwing on 17s or 18s with low profile tires and looking at lowering about 30mm after the new body kit goes on
Hmm...I've got 18s with low profile tyres and they scrub a bit after being lowered but nothing major. :)
18 works, 19 is pushing it.
silverGPX wrote:Nice supra
Manual '95 GPX
Lawso
Penis Fingers
Re: rims
Post by Lawso »
those are the stock evo tyre size. because its a whole 3cm wider i was expecting stupid amounts of scrubbing, but then again the offset fits brembos...
it'll be interesting
Re: rims
Yeah, but if you stick closer to rolling diameter surely it'd make it a bit easier.
I guess I'll be finding out semi-soon anyway how much set-up goes.
