Brakes
Brakes
Occasionally when brakeing, random pull to one side. Des that mean a caliper is fukinup?
Took the brakes off the other gpx and I think it's got ABS (has another lead that connects on the side near the brake line)?
Plan is to recondition and paint those calipers, then fit them straight onto mine. I want to make sure that its fine to put the abs calipers on the non abs car, Before I do this????
Re: Brakes
ABS is not part of the caliper, it is part of the hub, all GPX calipers are the same.
Re: Brakes
Why don't you just fix up the white car lol it's already manual and it's got abs and better paint...
Re: Brakes
Could mean you are tram tracking as well, or even that you need a wheel alignment. Uneven road surface will sometimes cause it, wheel alignment will make it worse.
    Re: Brakes
    Or your car has been in a crash and itll never be the same even after a wheel alignment
    Re: Brakes
    Yeah fould even be soft shock one side tyre not as good or even some air in line. Maybe one is seizing on too
    Re: Brakes
    Sahin wrote:Why don't you just fix up the white car lol it's already manual and it's got abs and better paint...
    Cos the motor's fuked.....
    silverGPX wrote:Or your car has been in a crash and itll never be the same even after a wheel alignment
    It only recently started doing this occasionally, so, no.
    vipfto wrote:Yeah fould even be soft shock one side tyre not as good or even some air in line. Maybe one is seizing on too
    Wouldn't be shocks, as they are new. Could be tyres as they seem to lose air a fair bit due to the dodgy paint job I did with the tyres on lol
    Ill check them
    Then get wheel alignment and fit the new calipers .. Should hopefully fix the issue.
    What is tram tracking?
    Re: Brakes
    But it's easier to drop a new motor in then do a manual conversion?
    Re: Brakes
    Not really conversion easy enough too
    Re: Brakes
    Sahin wrote:But it's easier to drop a new motor in then do a manual conversion?
    Not for me.. Wouldn't be able to do it.
    Ill be lucky to do the conversion lol
    I'm taking all of August off work just to get it done haha
    Re: Brakes
    Na mate if plan right right and your completely confident give it bout 3 days. Can be done in day easy enough with right tools and know how
    Re: Brakes
    what about when accelerating hard. it pulls to the side for a second, whats the likely cause?
    Re: Brakes
    Torque steer! :tongue:
