Clutch problem
Clutch problem
Hey guys,
I recently installed a HD clutch kit from ACT on my 6a13tt fto. The problem is if the car is cold I can't get into gear, "locked out". But, everything works just fine when the car warms up. The slave cylinder is barely moving the fork to flex the p/plate. I suspect that the master is bad. Any ideas?
Re: Clutch problem
Bleed the clutch hydraulics
Re: Clutch problem
Done that a few times. Similar to bleeding brakes.
- vipfto
Re: Clutch problem
yeah same principle, master or slave could be leaking although eventually your clutch wont work full stop.
- vipfto
Re: Clutch problem
also what condition is box in? possibly getting rather tired and only engaging when oil warm clutch fork doesnt really move much
Re: Clutch problem
20 bucks says the oil in the box is too heavy a grade. Been there.
Re: Clutch problem
Go back to a 75w-80 box oil.
Re: Clutch problem
80w90 is too heavy?
Re: Clutch problem
yeah
- vanadinite
Re: Clutch problem
this ^^
Re: Clutch problem
Get that Nulon stuff
and then G70
Re: Clutch problem ***Update***
I decided to pull the master and slave cylinder and discovered busted seals in the master. After cleaning and replacing internals I bled the system and clutch worked for a while. I then decided to lengthen the shaft in the slave and that solved it somewhat. Now I have a problem of the clutch slips at 4-5K rpm so I think I have to shorten the shaft a few mm more.
I did the clutch drag test (hold clutch in and rev till car starts to roll) it held till 7K so no drag I think.
Re: Clutch problem
Turns out my slave was also sticking so it was replaced but the stock actuator rod was too long so I altered a shorter rod. The problem now is it seems the clutch is slipping and I think this is due to the release bearing riding the p/plate. Is there some adjustment I can make?
- vipfto
Re: Clutch problem
Only adjustable part without removing box is at the pedal
Re: Clutch problem
If I'm unable to push the slave rod back with my hand is the pedal too far out?
