aftermarket mods
Private Sales Only
Kashikhan55
aftermarket mods
Post by Kashikhan55 »
good affordable aftermarket fuel pump, injectors and intake system for gpx
Re: aftermarket mods
Kashikhan55 wrote:good affordable aftermarket fuel pump, injectors and intake system for gpx
What for? You got boost?
Not yet :) slowly building up for it
Support mods first :p
ZFL45H1 wrote:Not yet :) slowly building up for it
That's the stupidest thing I've ever heard
Hahaha I know only thing I could come up with
Kashikhan55
^actually pretty much that
after going to get ecu and flash tune it to mods
Won't you be running uber rich if you don't do it at the same time?
Be lucky if it even starts.
The only off the shelf part there that you're after is the fuel pump. The 255L in-tank Walbro ITP257.
The intake will need to be custom made if you're going turbo, the injectors will need to be sized depending on what size turbo you plan on running.
Kashikhan55
^not running a turbo but yea fuel pump thing helped thanks and yea looking at custom kits on ebay or prolly get it metal fabricated
