BC BR setup
BC BR setup
What settings related to preload are you guys running? I was going to use 4mm preload like this vid: http://www.youtube.com/watch?v=HlqOA35NmAw
Any suggestions?
Re: BC BR setup
Mines just standard off the shelf specs
Re: BC BR setup
Just put them on? Didn't do any adjustments? hmm... I could move the springs around with my hand..so I thought preload was not properly set.
Re: BC BR setup
Oh fair enough mine where stiff as I couldnt move any part of them thats weird how that's happen
Are they all the one units when u got them or apart
Re: BC BR setup
All together. Rob (Vectose) confirmed as long as the springs don't have up and down movement then I should be all right.
What hardness/softness settings are you running on yours?
Re: BC BR setup
Thats a good question lol are you talking about the top you can adjust if so
Both from soft turn front 12 clicks to hard and rear 14 clicks
I find its a nice ride like that.
Spring rates I dont know what they are just what ever standard is
Re: BC BR setup
ZFL45H1 wrote:Thats a good question lol are you talking about the top you can adjust if so
Yeah those ... I have got standard spring rates as well. :)
Aren't you supposed to go from hard 0 to soft while changing those settings? I have got them at rear 20 and front 15... 0 being hardest, 30 being softest. Yet to put my front ones in though :P
Re: BC BR setup
Set 0 preload by winding top adjuster down so that the spring has a smidgeon of play, like u can move the spring a tiny tiny bit in its perch with force.
Re: BC BR setup
Even a tiny bit of preload adds bouncy ness
Re: BC BR setup
Vectose wrote:Hey mate, just wondering if you set the spring preload on the BC cpilovers or if you are running them how they came out the box?
There's no preload to adjust. They're not like Teins, the lower cup under the spring is supposed to be a 'neat' fit against the spring. Just tight enough so there's no slap, yet you can still turn the spring in it's place.
Re: BC BR setup
Shout me a carton and I'll install the lot sidds
Re: BC BR setup
I'll help for free
Re: BC BR setup
I'm more 1337 :lol:
Re: BC BR setup
Lol at leet
Re: BC BR setup
Sahin wrote:I'll help for free
Get your ass back from melbourne first :P
Re: BC BR setup
I'm back on the 5th lol f**k melbourne
Re: BC BR setup
Sahin wrote:I'm back on the 5th lol f**k melbourne
LMAO!!! :D :lol:
Re: BC BR setup
Anyone need anything from Dwayne on the way back lol
Re: BC BR setup
Sahin wrote:Anyone need anything from Dwayne on the way back lol
I need something from Melbourne :)
Re: BC BR setup
Me? Lol
