Inner CV shaft length?
MOR31
Post by MOR31 »
Hey guys,
Can anyone tell me the length of the passenger side, inner cv shaft. The one with the spline that goes into the box.
The one I have measures 62.15 in length (from the shoulder to the end of the spline)
Are there any that are 70-75ish mm long shafts found in the FTO
Re: Inner CV shaft length?
Yes, but they are rare as hens teeth.
62mm is the standard size that will fit both the standard full slip diff & the helical LSD (on both sides) - generally found in the 27 spline variety.
The longer one (accompanied by a shorter one for the other side) are generally 25 spline & only suit the earlier viscous LSDs...(in FTO's that is)
If you find more than one set, let me know lol. I have a viscous LSD for sale that's a bit hard to move without the odd length CVs!
MOR31
Post by MOR31 »
Yep that sounds exactly right. Is there any known part number for said shafts?
Having to swap my LSD fitted box for an open center so want to get this sorted asap
I have a single slip diff thats 27 spline
4G9XRR
Post by 4G9XRR »
So what inner cv's is needed for the 25 spline viscous lsd's? Are they both the same lengths or are they staggered in size as well?
Im thinking exactly the same in length just diffenent diameter thats all
No, the viscous limo ones are different lengths.
