Air Con
therealtbone
Air Con
Post by therealtbone »
Hey,
My Air Con is terrible, does not blow any cool air at all.
I was wondering how much it costs to regas it or to just replace the radiator?
Re: Air Con
As long as the system itself is sound (no leaks/damaged components), its just a regas. I think thats around $120. Do not run the aircon while there is no gas in it.
    Re: Air Con
    If there is no gas the air con shop will run a dye leak test. If there is no leak, then it's a simple refill as Dwayne mentioned. If there are components which are broken, compressor, evaporator, etc, that's when you are looking at good bills.
    Re: Air Con
    Where are you located, my dad is a fully licensed aircon guy, will look after u. But its near Brisbane, QLD
    therealtbone
    Re: Air Con
    I am in WA, perth
    yotka
    Re: Air Con
    Post by yotka »
    Try Acute Automotive/ Dean / 0412207814
    I used his services and mine was the second FTO he serviced, almost 2 years ago, so he is decently familiar with them.
    He has a call out fee, on top of the regas fees, so remember that.
    Additionally, he might recommend a drier/filter change, the part number for the aircon filter is RNIS16.
    You might want to make sure he has one in stock, before coming over for the regas.
    More information of my experience with him here: http://ftoaustralia.com/v3/viewtopic.php?f=21&t=25482
    Re: Air Con
    If you open the ac system, you should be replacing the drier filter and tx valve along with new o rings I think.
    Re: Air Con
    shadowarrior wrote:If you open the ac system, you should be replacing the drier filter and tx valve along with new o rings I think.
    Meh.
    Re: Air Con
    dstocks wrote:As long as the system itself is sound (no leaks/damaged components), its just a regas. I think thats around $120. Do not run the aircon while there is no gas in it.
    All Ac systems disable the air compressor when gas gets low. It's a fail safe.
    Regas goes for more about $180 these days.
    Re: Air Con
    yotka wrote:Try Acute Automotive/ Dean / 0412207814
    There is nothing special about the Fto cooling system. It's the same for every other car.
    Re: Air Con
    Got a shop-a-docket the other day for a $99 regas and leak check.
    Re: Air Con
    Score! :lol:
    Re: Air Con
    Fck!!! $99 is super cheap! :|
    HeRo
    Re: Air Con
    Post by HeRo »
    While we're on this topic: I had mine regassed early last year and the aircon works but barely on a hot day.
    Is there a way we can make the aircon even colder?
    c0n13oX
    Re: Air Con
    Post by c0n13oX »
    Ice cubes :lol:
    Re: Air Con
    HeRo wrote:While we're on this topic: I had mine regassed early last year and the aircon works but barely on a hot day.
    Maybe you have a slow leak and have lost heaps of your refridgerant.
    Re: Air Con
    Drive faster
    Re: Air Con
    Drive faster, naked with ice cubes
    Re: Air Con
    Even better ^^^
    Nacho
    Re: Air Con
    Post by Nacho »
    Drive faster while having sex with a snowman
