Replacing Crank Angle Sensor
Hey all,
So we're trying to replace Nick's crank angle sensor, but we're just wanting to confirm a couple bits.
One being that from looking at our spare engine, we must remove this pully, is that correct?
Which from some searching should lead us to this, with the sensor in place behind (not my pic):
Now, I'm assuming that to in doing all this we will have to remove the accessory belts?
Any help appreciated.
Thanks,
Braydon.
Re: Replacing Crank Angle Sensor
Knew this thread was coming lol.
See if you can get underneath?
Yes, you will need to remove accessory belts in order to get the harmonic balance pulley off.
Cheers,
I assume you loosen one of the tensioners to release the belts?
Technikhaus wrote:Cheers,
Both tensioners. Alternator one first, it's the one up top. First undo the centre nut on the pulley, then wind down the tensioner. Same with the bottom idler next, loosen centre nut, then wind in tensioner. Belts will all but fall off.
You'll need a bendy socket extension to get that top pulley or jack the engine till it clears the chassis rail lol
By the way, have fun with getting the harmonic balancer off! I had to use a socket set and put it on the bolt and crank the engine til it came loose but you can't do that seeing as though it's out of the car... So I hope you have a loooooooooong breaker bar
silverGPX wrote:You'll need a bendy socket extension to get that top pulley or jack the engine till it clears the chassis rail lol
no you don't you just need thisImageImage
You're a faggot lol
I can remove both belts in about 5 minutes lol
I just used a Bahco ratcheting spanner, it's slightly offset, so fitted fine and undid the bolts with no issues.
Fitted over both tensioners fine.
http://www.toolmanyardley.co.uk/product ... ductid=867
Sahin wrote:By the way, have fun with getting the harmonic balancer off! I had to use a socket set and put it on the bolt and crank the engine til it came loose but you can't do that seeing as though it's out of the car... So I hope you have a loooooooooong breaker bar
Considered doing this, I saw it done in a video, but we don't have a breaker bar long enough. :(
Kind of stuck on how to remove the balancer now. Our electric rattle gun isn't working, and the air powered one isn't powerful enough :cry:
Just get a long as pole! I dismantled my gym the other day for a breaker bar lol
nothing here to make one out of that would work :( Everything is large diameter thin walled :(
Hahaha euphemism
Just found one long enough and pushed it against the LCA and turned over the engine and it worked :D yay!
Cheers guys!
now removing the balancer itself... it won't pull off, and we don't have a removal tool...
I'd be removing the one off the spare engine first
Lever it, bit by bit, all the way around using a the largest pry bar / screwdriver you can fit behind it.
Use a big crowbar or pry bar to try get it off
f**k bennoz beat me lol
