Down on power, stalling, weird sh*t
Check engine light on intermittently (mostly on) and its down on power.. sometimes kicks in to full power at random times and engine light goes off. we replaced the stepper motor and adjusted the idle. it seems like it is OK when its revved a bit more and given full throttle..
Basically I drove to rock_its (from Botany to Sutherland) fine (until I was 100m away from Craig's - it stalled in neutral at the lights)
We replaced stepper at his, seems to be OK. I revved it up a little bit and it dropped straight down to 0 and turned off on its way back down from about 3k.
We figured electrical problem as my battery is sh*tty and voltmeter is at about 12 volts (Bobby's @ 13+)
So started to drive it home, got 100m down the road, it stalled while changing gears (not me lol, stalled with clutch in and turned back on when I let go of the clutch but kept going)
Another few hundred meters down the road it had engine light on, about 1/3 power so I pulled over and Craig came to help. While waiting I turned it on a few times, each time turned straight on then off again so when Craig got there we turned up the idle and seemed OK @ about 750rpm.
Then engine light stayed on, down on power usually (sometimes randomly got power - screeched the tyres a few times while power kicked in while taking off)
Seems to be OK at around 3,500rpm + but dunno if thats just by chance (still haven't taken it past 4)
Any ideas guys?
Also yeah I know I need to check codes, will do that when I get a chance, just wondering if anyone has had similar/same issue.
Any ideas guys?
Re: Down on power, stalling, weird sh*t
Check the codes.
Yeah just editedVectose wrote:Check the codes.
Won't get around to that until Saturday.. just wondering if anyone had ideas.
Head gasket
- MADFTO
If Voltmeter is at 12V while the engine is running, I'd be looking at your alternator.
It doesn't sound like a bad batch of fuel, I've had stalling issues with bad fuel in the past.
Caveat: I've got a lightened flywheel so I'm more susceptible stalling if the car isn't idling properly.
But yeah check codes.
Engine light => O2 sensor?
- vipfto
error codes fist, most likely dodgy sensor if ecu light on only way to check via codes
- rock_it
Cluster ...
But yeah, we need to DMM to ensure your volt gauge is accurate.. Cause it could have shifted when the aftermarket faces were put on. Like how I had to adjust Smurf...
But it does seem suspicious.. Sitting in the garage on idle for ages fine... Then drives out... Bam ... Maybe the car just doesn't like being in the Shire.. Cause that is when the problems started..
But don't worry, new place is in Panania ... So your car should be fine to visit..
Done a little research and I am now 99.99999% sure it is in fact the TPS.
That is exactly what is happening. I will have a proper look on Saturday, check my codes and swap out TPS for a spare one I have on Sat morning.FTO-IrelandForum wrote:A faulty TPS is usually noticible in that it can mimic problems caused by a faulty stepper motor, the main difference is the car can cut out / idle badly when warm.
Dammit where the hell is payaya!
f**k it's not hard to adjust lol. Loosen screws, twist left or right till fixed!
Mmk so still having issues when hot.
Have adjusted TPS, replaced dodgy lead (when it was firing on 5 yesterday at Fraz's.. random?)
Still doing weird sh*t... getting a multimeter when I can do adjust TPS to exact spec but aside from that, the only other thing I can think of would be coil packs shitting themselves..
Anyone else have any suggestions?
(Also, engine light is gone)
Have you checked the codes?
Yep... didn't show any, just constant blink
Although I am 99.9% sure that the code was for TPS (the plastic inside was shattered and spring fell straight out when I took the TPS off the throttle body) and I replaced it with a spare.
Engine learning to idle? Lol
Nup, idles fine when cold, warm, hot, but engine starts to sh*t itself after being on for 15 minutes or so.
- Shhtuart
Yeah try o2 sensor!
O2 sensor would only f**k around after running for 15-20 mins?
Shhtuart do you stock them or should I find one elsewhere?
- vipfto
Sure stepper is good?
O2 wont cause issue your having. Correct to look at coil packs too
