Hey,
So basically my clutch point is so high that it sometimes doesn't release the clutch properly.
Is there any way to move it down, even slightly?
Could clutch fluid level too high cause it?
Altering clutch point
Re: Altering clutch point
Wut
My clutch point is so high that sometimes the clutch doesnt even get released properly..
You spika the english?
Adjustment can be done to the linkage at the pedal. 12mm spanner is required I believe.
Just loosen the lock nut and then turn the push rod.
That'll do it.
Thank you sir!
Thank you sir!
What vectose said ^^^^
