car died
adzski
car died
Post by adzski »
was driving then all of a sudden i heard a back fire and spluttering and she died. still trys to crank but just wont turn over.
i was thinking maybe a fuel pump but probably not.
thinking some kind of sensor? anyone have have some ideas? dont know where to start looking.
Re: car died
Get codes.
Test cylinder compressions.
Test spark/coils.
Test fuel flow/pressure.
Check oil level.
adzski
Re: car died
Post by adzski »
cheers phil, ill check those sometime next week.
I have checked the oil level last night when it happened, was normal
Spark plugd were recently changed like month ago but will just go over everything again
adzski
Re: car died
Post by adzski »
i think i found the problem. 3 wires coming out of injector wiring has been torn up by the ac belt. just going to give it to the auto elecs
adzski
Re: car died
Post by adzski »
i attached a photo of what wires are torn. not my engine but same wires.
can someone tell me what they are for?
my poorly drawn circle and arrow, show which wires i am referring to.
adzski
Re: car died
Post by adzski »
i think its the crank angle sensor wiring? can someone confirm
Re: car died
That would be correct, Nick's was damaged when his P/S belt snapped as well, we swapped the sensor out and all was good.
His refused to start, and the Check engine light flashed the error code for the Crank angle sensor when we checked the codes.
adzski
Re: car died
Post by adzski »
kool. how hard is it to replace the sensor? considering just getting the auto elecs to come out and change it and fix wiring?
Re: car died
It's a bit of a pain in the backside, you have to remove the P/S and alternator belts etc, then remove the harmonic balancer, and the timing belt covers, then you can get to it.
If it's just the cable snapped and you can see the snap then you may be able to repair it without removing all that
We were able to do it in a few hours at home, but we didn't have the right tools etc on us, so with the right tools it'd be a reasonably painless job.
Re: car died
Hard to tell but are you sure that doesn't go down to the crank angle sensor?
Edit: sorry page didn't refresh before I posted. Yeah pretty sure is crank angle.
adzski
Re: car died
Post by adzski »
Daniel2019 wrote:Hard to tell but are you sure that doesn't go down to the crank angle sensor?
yeh i was looking over some diagrams before. pretty sure its the crank angle sensor
Re: car died
Same happened to me.
I was able to solder the wires back together without removing anything.
Re: car died
If you'd checked the effing error codes, you'd know by now :lol:
Re: car died
Bennoz wrote:If you'd checked the effing error codes, you'd know by now :lol:
This guy..
adzski
Re: car died
Post by adzski »
hahaha yeh i need to start checking error codes. i always just play with stuff till i fix it. would save time and $$$
Re: car died
adzski wrote:hahaha yeh i need to start checking error codes. i always just play with stuff till i fix it. would save time and $$$
Nah.
bumpak
Re: car died
Post by bumpak »
(yes that is your crank angle sensor 100%) I had my crank angle sensor foul up to. Obviously engine wont start if its not working, but the thing was it would display no error codes. I bet if u ground a wire on the diagnostic port it wont show up anything, unless of course its another code for something else. Lucky for me my first guess was crank angle sensor.
Re: car died
bumpak wrote:(yes that is your crank angle sensor 100%) I had my crank angle sensor foul up to. Obviously engine wont start if its not working, but the thing was it would display no error codes. I bet if u ground a wire on the diagnostic port it wont show up anything, unless of course its another code for something else. Lucky for me my first guess was crank angle sensor.
That's a bit odd... especially as there is a code (22) specific for the crank angle sensor.
Re: car died
So there's no funeral and free food and wine? dafuq? Misleading title. :|
Re: car died
shadowarrior wrote:So there's no funeral and free food and wine? dafuq? Misleading title. :|
I call BS, you're looking for upset, loose-moraled women in black, ya beat off :lol:
