5 speed auto conversion?
WoohYeahJunior
Post by WoohYeahJunior »
I've used the search button and can't seem to find anything but has anyone thought of going from 4 speed tip to 5 speed tip? (If it's possible that is). I feel 4 gears ain't enough and I might consider a manual conversion but I'd like to look into this first!
Would it be harder doing a 5 speed tip than a manual or is it a matter of finding a 5 tip gear box and doing some other modifications and that's it?
Re: 5 speed auto conversion?
Very hard to find a 5 sp box. I reckon the 4 sp is much better box or manual even better
5 speed autos are quite fragile, and wouldn't really be worth the work required to find and maintain one. You're better off getting a manual gearbox to be honest
I don't know why everyone says the 5spd is delicate. How many of you have actually had one? Mines 170,000kms going strong with an LSD.
I've had 2 fucked 5 speed autos lol
Sahin wrote:I've had 2 fucked 5 speed autos lol
Did they break?
One was fucked when I got it, and I neutral dumped the other one and broke it lol
Weak as piss but I think it's from irregular fluid changes over the years to be honest
Chebus
Post by Chebus »
Did I get one of those in the car I bought from you?
Nah that was a 4spd lol
Don't get the 5spd for the fact that they aren't as common.
The 4spd is more common and easier to attain.
There is no gain with the 5spd, even fuel mileage is negligible.
If it does break... and it is a Mitsubishi Auto, so eventually it will. You will be hard pressed to find a second. Took me the good part of 2 years to find one.
Source: Driver of a 5spd since 2007.
Manual please
Lol what about that 5 speed auto that was full of sand because the oil filter had been snapped off lol
Nah that just had an internal filter like phils galant lol worked that one out a while ago
WoohYeahJunior
Okay cheers for the heads up guys but put of curiosity. If I were to go through with a 5 speed auto, what would I need to make that happen? Also am I better off just buying a 5 speed instead of converting? I just like the luxuries over the GPvR such as the auto folding mirrors and sound deading, stuff like that.
Just whack a manual in ffs :lol:
WoohYeahJunior wrote:Okay cheers for the heads up guys but put of curiosity. If I were to go through with a 5 speed auto, what would I need to make that happen?
Clearance from a Doctor and a psychiatric evaluation..
Member in canberra detonated a 5sp tip too, so they are a problem.
cheers
Dwayne
    Bennoz wrote::lol:
    Thank you.. I am here all week.. Try the Schnitty..
    rock_it wrote:
    Bennoz wrote::lol:
    I will, maybe even the parmy :lol:
