Speed limiter
FTO-Love-Affair
Speed limiter
Post by FTO-Love-Affair »
Am I correct in saying that FTO's were from factory limited to 180kmh?
terry-dobson94
Re: Speed limiter
Post by terry-dobson94 »
Both of mine cut out at 180 km if that helps
FTO-Love-Affair
Re: Speed limiter
I'm sure I read somewhere a long time ago that they are limited to 180, and you're kinda backing it up. Never thought much of it til it clicked that my speedo goes to 200 and I can wind the needle past that quite easily. So I'd assume that my car has been delimited.
Re: Speed limiter
Yes they are limited, all it takes is cutting 1 wire to delimit it.
Re: Speed limiter
I think mine went to 220 when i was dreaming that i was speeding.
Re: Speed limiter
Has nothing to do with moving the needle. The speedometer is an indication, not the determining factor of the cars top speed.
And FTOs were limited to 190Kph from factory
Re: Speed limiter
Yup, 190KM/h is where mine cuts out. So I've heard.....
Re: Speed limiter
270 km/h out of mine :P
Strkszone
Re: Speed limiter
Post by Strkszone »
How does one delimit their FTO? =o
Re: Speed limiter
Hold it flat till the limiter breaks
Re: Speed limiter
And don't listen to Toby.
Have a search, it's in the forum somewhere, tells you which wire to snip coming out of the ecu.
