Sound Behind Steering Wheel
- Strkszone
The car still drives fine, but every time I turn the wheel it sounds like something has been knocked loose and is clacking like a lego that has been chucked behind my steering wheel. Any ideas on what it can be..? It happened right after some dickhead pulled out in front of me and I pressed the horn pretty hard.
Re: Sound Behind Steering Wheel
Probably smashed the horn button and it's broken and rattling around now. They shatter pretty easy.
- Strkszone
Yeah, think you're right... but the horn still works. Any idea on how I can just remove the bits out of the horn and replace the rubber bit?
Prefacelift yeah?
That centre rubber cover just pulls off I think.
- Strkszone
More concerned about fitting it back in than anything else, do I just use a screw driver to jimmy it back in? I don't wanna remove it without knowing how to put it back aha xD
Just pull it ya wuss, goes on the same way
- Supplanter
I think there is a screw at the back that you need to remove before you can pull the front off.
Yeah there's a screw behind it on the bottom spoke
