Alright so in my 95 GPX my power windows and air / climate control won't work. I've checked all my fuses and still nothing. i have no idea what it could be.
one day it will be all fine the next i will have nothing. I've looked for triggers but i can't see anything that would trigger it. happens very randomly.
need help asap :'(
Air Con and Power Windows HELP!!
- Huckel___
- Moused
Re: Air Con and Power Windows HELP!!
Do they both work/not work at the same time?
I've had issues with power windows in the past, especially on older cars..
Dirty switches can be a good culprit, and cleaning the contacts in the switch can work wonders.
This might be a good starting point for your windows.. If they're failing at the same time as the aircon, but... It's likely not this.
- Supplanter
Which fuses did you check? There are some located on the passenger side of the engine bay near the battery, and some under the dash in the driver foot well.
