Car has trouble starting.
- Supplanter
I haven't been driving my car much lately, maybe once every two to three weeks. Recently, it has been stalling when I first start it, and I need to keep the revs up a bit for 10 to 15 minutes before it will idle properly. I thought at first the battery might be slightly flat so I have been trickle charging the battery and the voltage seems to be ok (tested with a multimetre). When I last had the problem a few days ago, once I got it going I drove it for an hour, including stopping several times for errands and fuel, and it started fine each time. Today when I tried to start it, it stalled again.
Re: Car has trouble starting.
Probably just learning the idle again, odd that it's doing it so often though....
Mine only does it when the battery has been disconnected.
- Supplanter
That's why I thought is was the battery at first, but I just measured it at 13.3V.
Stepper Motor
- Supplanter
I just had a brilliant idea, why don't I check the error codes.
62 Intake air control valve position sensor
Have you tried checking error codes?
- Supplanter
Yeah, it said I need that plastic bit that goes around the gear stick.Daniel2019 wrote:Have you tried checking error codes?
Have you got the bit that goes around the stereo? Mine's all cracked
- Supplanter
Given that am a ya mama is listing a Hyundai part as well as the Mitsubishi part, can I just get the Hyundai one, because it is a fair bit cheaper. :sidds:
http://www.ebay.com.au/itm/BRAND-NEW-ID ... 2588e8b239
