Car wont start
- Strkszone
Car wont start
Not entirely sure what exactly is wrong here so I'll just explain what's happened.
I recently went on holiday and before I left to go on holiday, my car has been completely fine. It hasn't been driven in 9 days and I've come back to it having a flat battery. I jumpstarted the car and it ran fine up until the point I turned it off (I left it on for around half an hour before determining that it was fine to switch off). The car runs so long as it isn't switched off even with all externals turned on maximum. Although the battery voltage meter has been bouncing around a bit when certain things are turned on. For example: whenever the hazards are pressed the dial ticks low then middle. Does anyone know if this is just a battery problem or a problem with something else like the alternator. I don't think it's the alternator since the battery is being charged and hasn't died on me while the car was on... but I could be mistaken. Any insight at all would be helpful, thanks.
Re: Car wont start
Volt gauge jumping around is fine, that's normal. Will drop when headlights are on etc.
Sounds like your battery just needs a proper charge. 1/2 an hour running isn't really that much. Try a battery charger overnight if you have one.
- Strkszone
Re: Car wont start
Don't have one, any idea where I could get one for cheap?
Edit: Also any idea why it would've just gone flat after not being driven for 9 days? Surely it doesn't need to be driven *that* often, does it?
Re: Car wont start
No, but if your battery is on the way out it might do it, or if you left your lights on or something.
- Strkszone
Re: Car wont start
Battery is less than a year old and no lights were left on. I've been meaning to see if there is anything drawing charge out of my battery whilst everything is switched off.
All aftermarket electronics in the car:
Head unit
HID lowbeams
LEDs in the footwells (on when switched or door is open)
All others are stock.
I can't imagine that the LEDs are drawing charge out of the battery when set to "Door."
The car makes a racket if you leave the headlights on, so I'm confident I didn't leave them on either... :/
The battery is from a company called Super Charge if you've ever heard of 'em before.
Head unit
HID lowbeams
- rock_it
Re: Car wont start
Do you have an alarm?
I remember my car would last about 2-3 weeks without going flat ... The less I drove it, it started to drop real quick after that.. I think I ended up getting about 7-9 days on average with the battery that was in it.
But by this stage, the batter was about 2 or so years old.
I ended up buying a trickle charger from Super Cheap. Was about $90 and you constantly leave plugged into power, and on the battery. It drops charge in and out depending on if the battery needs it. I would then alternate what car I had the charger on while I would cycle through and eventually take them all ...
It even had small clamps to attach to my motorcycle battery ...
- Strkszone
Re: Car wont start
The car came with an immobilizer but I deactivated it. This is a relatively new battery, probably only a couple months old. I'll look into getting a trickle charger then, thanks.
Re: Car wont start
Shouldn't have to use trickle charger though. Something is fubar.
Re: Car wont start
$50 on bad earth!
- Strkszone
Re: Car wont start
Ended up getting the battery replaced. Alternator is running fine. The autoelectricians said that the battery has been cooked and multiple cells are simply not functioning. It wasn't accepting any charge it was just flat out gone. Any ideas what can cause this...?
The battery is a Super Charge MF53 with a CCA of 650 and Max Charging Volt of 14.8.
The new battery is making the car run fine... but I suspect it's only a matter of time before this one goes too...
Re: Car wont start
Can sometimes be heat that causes that.
- Strkszone
Re: Car wont start
Just took it to an autoelectrician for an Argus Battery Test Report
Drainage = 0.16A
Battery age: 3 days
Recommendation: Replace Soon
Technician:
Battery Model:
Battery Type: MF
Battery Standard: SAE
Reference Value: 650CCA
State of charge: 100%
Voltage: 12.97V
Battery Temperature: 33C/91F
Capacity Test: Warning
Battery Life: 47%
Capacity: 564CCA
Cranking Health Test: Pass
Cranking Health: 100%
Voltage: 10.35V
Charging System Test: Pass
Voltage: 13.92V
Diode Ripple: Pass
Tester Model#: AA500P
SW Version#: v2.8
3 days old and the capacity test is at 50% with a recommendation to replace soon? Wtf..?
Drainage = 0.16A
Battery age: 3 days
Technician:
Battery Model:
Battery Type: MF
Voltage: 12.97V
Battery Life: 47%
Capacity: 564CCA
Voltage: 10.35V
Voltage: 13.92V
Diode Ripple: Pass
SW Version#: v2.8
Re: Car wont start
Fucked alternator or sh*t earth.
- Strkszone
Re: Car wont start
Alternator operating fine they said, same for voltage meter. Was told a drainage of 0.16A is the equivalent of leaving the interior light on pretty much. No idea what to make of that...or if anything is causing that like an alarm system or whatever. Just hoping to find out what it is so I can fix the bloody thing ;_;...
