2 Upper Engine Mounts
I did also have this in discussions but figured I'd put it here too.. I need 2 Upper Engine Mounts for my facelift 97 GX.. The facelift mounts are larger then the pre's so there is a difference.. If anyone's got any.. Or if you have any after market mounts that would also fit I'll buy them too
Re: 2 Upper Engine Mounts
It's just the drivers side engine mount that's different. The gearbox side is the same. For the manual that is.
Also the ralliart inserts for the upper mounts are the same part. So you would buy two of the same insert.
Hmmmm, Its possible ill have them. Are you coming to the bonfire??????
I got some too
Hahaha dstocks I want to
That's why I'm trying to get it all roadworthy for the trip down.. I live up near Brisbane now so it's a bit of a drive.. But well worth it!!
Would yours fit my facelift manual sahin?? Vectose said there would be a difference in sizes for the drivers side.. The ralliart one I already gave my mechanic apparently slipped straight through
Yep, Sahin is closer if you are in brissy, so is probably best getting from him if you can. Use me as a backup.
cheers
Dwayne
cheers
Dwayne
