helping a friend buy an fto: gearbox nois
Invader_X
Post by Invader_X »
So I took the fto that we were looking at to my mechanics
We put a long metal rod on the gear box and we can hear vibrations th rough the rod to ear.
Could this just be low on fluid? No crunches or anything.
GR model 171,000 kms on clock
Anyone have any similar experience
Re: helping a friend buy an fto: gearbox nois
Could be low, but could be a few other things, worn bearings etc.
There's a big ugly c**t around here somewhere that rebuilds them
Primary input shaft bearing. Bout the same size as Toby's brain, but worth more.
Invader_X
Post by Invader_X »
Bennoz wrote:Primary input shaft bearing. Bout the same size as Toby's brain, but worth more.
Input shaft bearing is an item to be replaced when clutch is changed?
On another friend's FTO vibration seem to happen between 2000 - 4000 rpm, would that be it too? 1994 GPX
Or if you aren't getting free labour to pull out, fix and replace bearings... Just buy Lawso's box...
Just noticed you are in NZ ...
Invader_X
Post by Invader_X »
Ha yes I am. From Nu Ziland ;)
Invader_X wrote:Ha yes I am. From Nu Ziland ;)
Kia ora bru ...
Invader_X
Post by Invader_X »
Kia ora because ...
I'm not Maori doe
Nup, input shaft bearing is in the box. Time to put a full bearing kit through it. We buy them from Cobra transmissions in the US. If you search you'll find the part number here.
Invader_X wrote:
Kia ora because ...
I'm not Maori doe
And I had to change it, due to the W0rD F1lter ... Thanks Bennoz...
