Installing LEDs for dash gauges
- prageeth
Hi
I'm in the middle of installing LEDs for my dash. I noticed Climate Control's LCD does not light up with 12v LEDs. I'm talking about the 2x T4 or T5 bulbs at the back of the LCD screen. When I checked, they are 5v with 'Ignition On' and 7v with 'Park Lights On' or other way around, but definitely not getting a 12v. Has anyone come across this issue before?
Other 2 LEDs for buttons of the climate control work fine with 12v LEDs.
Cheers and thanks.
Cheers and thanks.
- Supplanter
Re: Installing LEDs for dash gauges
They normally dim when you put your lights on.
- prageeth
They do. But I reckon that function won't work if I replace factory bulbs with LEDs.. obviously. I'm happy if they just light up and stay with the same brightness.
- kiz
- SA Coordinator
I'm pretty sure people have already done this. I can't remember who, but someone will probably pipe up about it soon enough
1998 Mitsubishi FTO GPVR AERO
- Shhtuart
This man is the local expert of all things electrical.Supplanter wrote:They normally dim when you put your lights on.
- kiz
- SA Coordinator
Some say he can put a "spark" in your lifeShhtuart wrote:This man is the local expert of all things electrical.Supplanter wrote:They normally dim when you put your lights on.
- ObsidianRadio
Others say it's an enlightening experiencekiz wrote:Some say he can put a "spark" in your lifeShhtuart wrote:This man is the local expert of all things electrical.Supplanter wrote:They normally dim when you put your lights on.
- Shhtuart
I've heard he's every down to earth.ObsidianRadio wrote:Others say it's an enlightening experiencekiz wrote:Some say he can put a "spark" in your lifeShhtuart wrote:This man is the local expert of all things electrical.Supplanter wrote:They normally dim when you put your lights on.
- SchumieFan
I heard he likes his balls tickled with two hands...
http://ftoaustralia.com/v3/viewtopic.php?f=23&t=1891
- prageeth
Thanks. I saw that post. But for some reason, 12v LEDs don't light up behind the climate control's LCD panel.
- Moused
Potentially stupid question, but figured I should ask.. The polarity isn't the cause, right?prageeth wrote:Thanks. I saw that post. But for some reason, 12v LEDs don't light up behind the climate control's LCD panel.
- kiz
- SA Coordinator
Well LEDs will only work one way around, so very probableMoused wrote:Potentially stupid question, but figured I should ask.. The polarity isn't the cause, right?prageeth wrote:Thanks. I saw that post. But for some reason, 12v LEDs don't light up behind the climate control's LCD panel.
- Supplanter
I currently have LEDs in the climate control, they do dim when the lights are turned on.
- prageeth
Thanks, but I was aware of it. On these dials negatives are on the top and positives are below. I checked it in the first place.kiz wrote:Well LEDs will only work one way around, so very probableMoused wrote:Potentially stupid question, but figured I should ask.. The polarity isn't the cause, right?prageeth wrote:Thanks. I saw that post. But for some reason, 12v LEDs don't light up behind the climate control's LCD panel.
- prageeth
That's great. I might give mine another go. I'm pretty sure my LEDs are not dimmable.Supplanter wrote:I currently have LEDs in the climate control, they do dim when the lights are turned on.
- Moused
Seemed like you would've, but figured I'd ask just in case... Nothing worse than banging your head against a wall trying to figure something out, and the cause is so simple.prageeth wrote:Thanks, but I was aware of it. On these dials negatives are on the top and positives are below. I checked it in the first place.kiz wrote:Well LEDs will only work one way around, so very probableMoused wrote:Potentially stupid question, but figured I should ask.. The polarity isn't the cause, right?prageeth wrote:Thanks. I saw that post. But for some reason, 12v LEDs don't light up behind the climate control's LCD panel.
- prageeth
Yes you are right. That has happened to me a lot of times, simple things seem to be forgotten easier.Moused wrote:Seemed like you would've, but figured I'd ask just in case... Nothing worse than banging your head against a wall trying to figure something out, and the cause is so simple.prageeth wrote:Thanks, but I was aware of it. On these dials negatives are on the top and positives are below. I checked it in the first place.kiz wrote:Well LEDs will only work one way around, so very probableMoused wrote:Potentially stupid question, but figured I should ask.. The polarity isn't the cause, right?prageeth wrote:Thanks. I saw that post. But for some reason, 12v LEDs don't light up behind the climate control's LCD panel.
