engine removal
engine removal
Can anyone tell me the Easy way go remove the engine and is there a main plug for all the engine wire and sensors and how many engine mounts is there
Thanks in advance
Thanks in advance
Re: engine removal
Uhhh...
No you need to pull individual plugs.
Drop engine out the bottom and slide it out from underneath is the easiest way.
One engine mount, one gearbox mount and two mounts on the crossmember.
Re: engine removal
Thank you that will keep me busy
Re: engine removal
It sure will
Re: engine removal
Just slide it out aye.
... U gotta jack it up pretty fkn high. It pulls out The top with a crane easy enough if you've got one...
Re: engine removal
Not really? That's how we got Dan's engine out.. had no problems with it. That's how we got mine out of the black car originally too.
Re: engine removal
We lifted Dan's engine out. Dropped the gearbox first though.Daniel2019 wrote:Not really? That's how we got Dan's engine out.. had no problems with it. That's how we got mine out of the black car originally too.
Re: engine removal
Wut? Did we...? Why do I remember you lifting the front of the car with your hands then?
Well, Dwayne and I (and you from memory actually) got mine out from underneath in Dwayne's shed.
Re: engine removal
Yup, we used Dwayne's tractor to lift the car up.
- bjk
- Totes
Re: engine removal
Straya!Vectose wrote:Yup, we used Dwayne's tractor to lift the car up.
- SchumieFan
Re: engine removal
Yeah out the top is easiest... cam do with gearbox attached too with some maneuvering...
