HID Kits
Moused
HID Kits
Post by Moused »
I'm just after a decent kit...
Curious if anyone has a recommended brand, or price range.. What I should avoid, etc.
Also how will they hold out in the stock headlights? Would a projector be needed?
BorepYano
Re: HID Kits
Post by BorepYano »
the stock headlights are projector headlights;
make sure they use digital ballasts and the units are water proof;
I'd recommend wiring in relays;
Spend the time to double check your wiring, and do the wiring properly (i.e. make sure the crimps are tight, use solder, use heat shrink);
plan the job. Mock up where everything should go first; leave extra wiring, you can always trim it back, but it's a bitch to add 2cm of wiring later.
I've used a couple of random sets bought off ($50ish each set, off memory) they were both alright. 1st set flickered after a while, although it might have been my rushed wiring than the kit's fault. I spent a bit of extra time wiring up the 2nd set, also wired in a couple of relays; worked perfectly.
Scorpionwally8
Re: HID Kits
Post by Scorpionwally8 »
I just put a set into my fto , brought them for $67 6000k for my low beams,
Moused
Re: HID Kits
Post by Moused »
Thanks Bo, awesome info there
Scorpionwally8 wrote:I just put a set into my fto , brought them for $67 6000k for my low beams,
Where'd you get them from? Happy with the quality?
Scorpionwally8
Re: HID Kits
Yea I'm happy I got them off eBay ,was from a Queensland company
Re: HID Kits
I got mine from The Retrofit Source, they're expensive but great quality, and have had no issues at all with them.
Moused
Re: HID Kits
Post by Moused »
Are the relays required?
BorepYano
Re: HID Kits
Post by BorepYano »
Moused wrote:Are the relays required?
technically no; but a good idea. They are fairly cheap and easy enough to install, to be worth the effort IMO.
saves the switch from possibly burning out; and lessens the chance of damage due to under powering the ballasts from dodgy and/or old wiring.
Moused
Re: HID Kits
Post by Moused »
Where would one look at getting the relays?
What would they need to be rated? Very hazy about relays.
Re: HID Kits
Just a standard 30A or 40A horn relay from Jaycar or any auto parts store.
BorepYano
Re: HID Kits
Post by BorepYano »
Vectose wrote:Just a standard 30A or 40A horn relay from Jaycar or any auto parts store.
40A? over kill much? lol. I guess there's no harm, since they are all about the same price anyway.
If you can't find those, anything over 6A or 9A will work.
i.e.
35W kit @ 12v = 3A; they do draw up to double on start up, therefore 6A+. or;
55W kit @ 12v = 4.5A; they do draw up to double on start up, therefore 9A+.
Re: HID Kits
:lol: Most of the automotive relays sold in auto parts stores are 30/40a.
Re: HID Kits
I wouldn't worry about it in the beginning, only if there is an issue... Waste of money and time otherwise
BorepYano
Re: HID Kits
Post by BorepYano »
silverGPX wrote:I wouldn't worry about it in the beginning, only if there is an issue... Waste of money and time otherwise
I'd waste the $12 on 2 relays to not have to worry about potentially having to re-do all the wiring and maybe replacing the HID's. (although I have to admit, that has a lot to do with realising just how dodgy my original wiring job was)
Moused
Re: HID Kits
Post by Moused »
Eh, few bucks more to throw the strain on the relay makes sense..
Hoping to have it wired up sometime soon. I hope these cheap ass ebay ones are decent! lol
Scorpionwally8
Re: HID Kits
Mine work fine and I didn't bother with relays
Moused
Re: HID Kits
Post by Moused »
Welp, I installed a cheap ass ebay kit today... I also grabbed a relay 'kit' off ebay too.
All plug and play, enough wiring to get where it needed to, lights are working - waiting for it to get dark so I can actually see how decent they are.
$60 in total. The ballasts are apparently waterproof... I'm not so sold, so hopefully I've placed them in nice dry areas.
Hopefully they hold out for a long time to come - thanks for all the advice :thumright:
Next on the list methinks I'll fix up the peeling headlights.
BorepYano
Re: HID Kits
Post by BorepYano »
good work, where did you end up tucking the ballasts?
oh.. guess it's too late to suggest a LED conversion instead? :mrgreen: :mrgreen:
Moused
Re: HID Kits
Post by Moused »
BorepYano wrote:oh.. guess it's too late to suggest a LED conversion instead? :mrgreen: :mrgreen:
Yes, yes it is :hmm: lol
As for the ballasts, I'll grab some pics later.
prageeth
Re: HID Kits
Post by prageeth »
I have some experience with a few eBay HID kits on my FTO. Finally I found this good ones and am using for a couple of years. In fact, Philips may be the best but I couldn't afford a $1000 HID kit.
Check this link out;
http://www.ebay.com.au/itm/281437367367
I have HB4 for my low beam with 6000k, 35w. Happy with it so far. They gave me a 2 or 4 year warranty, can't remember. (Invoice is at home).
Here is the most important thing to me when I made the decision to buy this HID kit.
Quick Start: 0.05 Sec start, 1 Sec get 80% bright. (the normal kit in the market need take about 8 Sec )
Previous kits I had took a minute to come to the full brightness.
Some comments from the seller;
"it is the same factory which make the ballast for PHILIPS. and we can send this kit with CN-light too, which is the best quality made in China too."
Good luck
