Poor Fuel Economy
- mezje
Poor Fuel Economy
So I am getting about 350-400KM when the car hits E, when it is on E though I can usually fill it with about 10L of fuel, isn't it a 60L tank?
I also get a serious smell of fuel when I put the foot down.
Anything I can do to improve it, replace O2 sensor?
Re: Poor Fuel Economy
mezje wrote:So I am getting about 350-400KM when the car hits E, when it is on E though I can usually fill it with about 10L of fuel, isn't it a 60L tank??
what
If it's on the E and your filling up, & it only takes 10L to fill here back up to full, then you have a faulty fkn sender or gauge lol
& also a sh*t load of fuel still in the tank
- mezje
Maybe I worded it badly, but I will fully fill it up, reset the trip counter and I will get about 350-400KM before the gauge is on E again. When I go to fill it up at this point the car takes in about 45-50L of fuel, meaning there was still 10L left.destinationtoby wrote:mezje wrote:So I am getting about 350-400KM when the car hits E, when it is on E though I can usually fill it with about 10L of fuel, isn't it a 60L tank??
what
mezje wrote:Maybe I worded it badly, but I will fully fill it up, reset the trip counter and I will get about 350-400KM before the gauge is on E again. When I go to fill it up at this point the car takes in about 45-50L of fuel, meaning there was still 10L left.destinationtoby wrote:mezje wrote:So I am getting about 350-400KM when the car hits E, when it is on E though I can usually fill it with about 10L of fuel, isn't it a 60L tank??
what
Ohhhhh.
Um yeah, could be a number of things causing to run rich. Check plugs.
Could be faulty O2 sensor. If u can smell fuel I'm guessing u Have checked for a leak in lines and around filter area? Has the filter been changed recently ?
- mezje
I have not checked the filter or changed it, will give it a look, I can't see anything visible leaking near it though.destinationtoby wrote:mezje wrote:Maybe I worded it badly, but I will fully fill it up, reset the trip counter and I will get about 350-400KM before the gauge is on E again. When I go to fill it up at this point the car takes in about 45-50L of fuel, meaning there was still 10L left.destinationtoby wrote:mezje wrote:So I am getting about 350-400KM when the car hits E, when it is on E though I can usually fill it with about 10L of fuel, isn't it a 60L tank??
what
Ohhhhh.![]()
You mean check spark plugs ye?
I'd start with changing fuel filter & the ECU temp sender
- bjk
- Totes
Don't worry Toby, didn't make sense to me either.destinationtoby wrote:whatmezje wrote:So I am getting about 350-400KM when the car hits E, when it is on E though I can usually fill it with about 10L of fuel, isn't it a 60L tank??
- bradicus
my fuel economy is worse than expected aswell
- aza013
- NSW Coordinator
Its a sports car, if you are worried about fuel usage then you picked the wrong car
But yes you should be getting anywhere from 450-650K's to a tank. Pending on how you drive it.
- bradicus
i saw it was rated at 9.5 L per 100ks which is fine, beats pretty much all other v6s ive seen. but when it comes to driving seems to be worse than that
- Dras
Start simple (cheap). A dirty air filter can make a huge difference.
- bradicus
im guessing it could be the fuel filter too, but yeah worth changing the air filter, it came with a pod filter and its pretty dirty...
- mezje
Yep, hitting 450 would be good. Filled up today when it just hit E and I filled it with f**king 17L, the car had just hit 380KM so perhaps it isn't as bad as I think, I will give the car a solid drive soon and check the filter.aza013 wrote:Its a sports car, if you are worried about fuel usage then you picked the wrong car![]()
The gold part of the fuel insertion point (wtf is this called???) sometimes falls out, could it not being sealed properly reduce fuel economy?
- bradicus
What kind of petrol are you filling up with?
- bjk
- Totes
Ban hammer if it's anything other than 98 octane or higher lol
Just because it hit the E doesn't mean the entire 60l (or whatever it's supposed to be) is gone lol try driving it until the light comes on, then keep driving it as far as u can with the light on lol you'll be surprised how much fuel is actually left in there. Filling up and saying I'm 17l short, just means the last time u filled up it was a little less full ...mezje wrote:. Filled up today when it just hit E and I filled it with f**king 17L,?
Last edited by destinationtoby on Wed Dec 09, 2015 8:33 am, edited 1 time in total.
Fill up fuel tank until full, fill a Jerry can with 5L, drive till it dies = true km reading
- Dras
Don't do that.. muppets. Fill up to as full as you can get it. Drive it around until you're near empty then fill it up to as full as you can get it again then compare liters you filled up to distance travelled.
