Hey,
So my cluster lights stopped working for my speedo, tacho, fuel and temp gauges. All other lights work fine (indicators, check engine) and the volt and clock work aswell. I tried changing the light but to no avail.
Is this just a bad ground possibly?
Sent from my SM-G930F using Tapatalk
FTO Cluster Lights
- bjk
- Totes
Re: FTO Cluster Lights
I checked the fuse box aswell (should have mentioned) but theure all fine, strange thing is it sometimes works for a few seconds or even days but then nothing
Faulty dimmer switch installed upon importation for sure
Is the cluster pushed into the loom plugs properly?
Are the tracks on the rear of cluster damaged at all??
- Supplanter
It was the dimmer! Thanks Sahin, and everyone else too
This has been bugging me for months!
