Will these tyres fit??
Mivec swapped gx
Post by Mivec swapped gx »
Anyone know if 235/40zr18s will fit my gx, its not lowered just got bilstein front and kyb back shocks.
Thanks in advance
Re: Will these tyres fit??
They can, but there will be more issues compared to a smaller diameter tyre.
What size wheel do you want to run them on?
Mivec swapped gx
Im getting a set of 18s of my mate
What width and offset are they? Those will determine if you're going to need to roll the guards or not, although you might get away with it if not lowered.
Mivec swapped gx
235 wide and 40 offset i think
No, that's the tyre lol, I mean actual wheel specs
They probably won’t fit under the spring seats either, will need coilovers
mezje
Post by mezje »
Sahin wrote: Tue Jan 02, 2018 10:13 pm They probably won’t fit under the spring seats either, will need coilovers
No chance they will fit under the spring seats.
Yeah they will, you just need a lump hammer & an angle grinder.
Are the Bilstein shocks shorter like the Volvo ones? If they're not there might be a chance you could get it under. I fit a 235/45R17 under the stock shock spring seat.
Ephercius
Post by Ephercius »
Mine has 265 40 18inch at the back
