GPvR Rear LCA difference
Hi guys,
According to the viamoto site:
https://www.viamoto.co.uk/proddetail.ph ... m+Rear+ARB
It says:
"Fits GP version R Models with 20mm ARB
Will also fit other Mivec Models as long as fitted as a pair."
What is the difference if anyone knows?
I assume perhaps the tabs for the swaybar are in a slightly different location?
Re: GPvR Rear LCA difference
They have a plate on the bottom for extra rigidity iirc
Is that the only difference though?
Doesn't seem like that'd be something that would prevent only fitting one of them?
I wouldn't fit a mismatched pair. It's a big plate, factory designed to stop flex in the arm caused by the bigger swaybar.
We covered off on this years ago. It's probably in the suspension thread. I ended up welding some up, before moving onto the alloy arms.
spetz wrote: Wed Mar 14, 2018 10:43 pm Is that the only difference though?
It would make a heap of difference in your highly calibrated lancer.
I already have those plates on my LCAs though I am not sure what car they came from.
I suspect that perhaps the ARB tabs are at slightly different locations though to make the ARB less/more effective
