mivec head on a GR engine
cadburyboii
Post by cadburyboii »
is it possible to put a mivec head on a 6A12 non-mivec engine and if so how much and where can i grab one from?
You'll need 2 of 'em matey :wink:
jester
Post by jester »
cadburyboii..
is it safe to assume u have a GR? :?:
smorison
The Godfather
Post by smorison »
mivec has variable intake and exhaust cams so the short answer is no...
there are also variable intake runners and a ton of other stuff that go into a mivec engine....
if you were even going to consider this as a viable option then i recommend dropping in a mivec engine you'll save a heap of money
FTO338
Post by FTO338 »
I know someone had fitting a GR block with MIVEC head, as the block are exactly the same, all those variable inlet....etc are part of MIVEC head, so I don't see why you can't do it.
FTored
Post by FTored »
So it will work fine. Are you sure there FTO338? And you ll only need half an engine. Hmm. Nice. I'll add it to my to do list.
FTO338
Post by FTO338 »
I'm am very sure, as I've seen this person & his FTO a lot of time since he done it, & the car run just like any other MIVEC motor from the factory.
