Mods that led me to 14.320 @ 96.90mph wd 2.159 60"
HRD2BQT
Post by HRD2BQT »
Hi guys
Here's my latest mods that dropped my ET from 14.6 to the above.
PRO-IIDA 3-1 Headers
2.5 High Flow Cat + 2.5 Exhaust Piping + 5Zigen Fireball
65mm TB (off TR Magna)
Malpassi Fuel Pressure Regulator (set to 45psi)
DIY Headlight Cold Air Duct
225/50/16 Dunlop Formula Street tyres (18psi)
(1) 14.392 @ 94.95mph wd 2.160 60"
(2) 14.370 @ 95.03mph wd 2.145 60"
(3) 14.320 @ 96.90mph wd 2.159 60"
Strip Interior (Back Seat, Passenger Seat, Door Trims)
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
[url=http://z8.invisionfree.com/tgz_gc/index.php?showforum=23]J-Spec MotorWorks[/url] [b]<---click here [color=Red]NOW TAKING ORDERS!!![/color][/b]
barfy
Post by barfy »
So how easy was it to put the Magna TB in were there any mods needed ??
[img]http://i142.photobucket.com/albums/r103/barfy76/barfycopy1.jpg[/img]
HRD2BQT
Post by HRD2BQT »
it aint that hard...as a matter of fact It's fairly easy.
The TB itself is a bolt on unit but I swapped the bottom part (water/coolant valve i think it is) of the FTO's to the Magna's TB to make use of the OEM hose fittings. The one's on the Magna is facing the opposite direction, u can still use it but you'll need to change the hose fitting to a longer ones.
I dont have any dyno figures yet but I can feel a much better throttle response. And thats without boring the intake path. Expect to get more result if the intake patk is bored out to match the bigger TB.
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
p13nox
Post by p13nox »
How difficult are the throttle bodies to source? I'm in the UK, but would like to get hold of a 65mm TB.
Any offers? :D
Have a look at our wreckers: http://www.partslocator.com.au/ to see if you can scratch one up there. Otherwise, make one yourself!
Here's a thread from the UK forum - guy makes his own 63mm, but its all dependant on what size butterfly you can buy. I know the 65mm one is an off the shelf part...
http://www.ftooc.org/phpbb/viewtopic.php?t=32224
FTO338
Post by FTO338 »
HRD2BQT wrote:it aint that hard...as a matter of fact It's fairly easy.
Now thats good stuff, well done. TB Magna here I come...heheehe
Hehehe.. and here I am thinking 'bugger!'
went and bought a second stock FTO one & sent it to the machine shop!
Just last week too! :oops:
barfy
Post by barfy »
Hey HRD2BQT
You couldnt post a pic of your engine could ya, wouldnt mind seeing what it all looks like
d_stroy_r
Post by d_stroy_r »
i got the same stuff except throttle body and the fuel pressure regulator.
I'm down to a 15 flat.
It's not too hard to get a sub 15 sec 1/4 mile time.....just got to experiment :twisted:
FNTSY
Post by FNTSY »
that is a great time for a N/A fto.....
awsome work....
FNTSY MOTORSPORTS NEWCASTLE
###for all your boosting needs###
HRD2BQT
Post by HRD2BQT »
hey guys,
for those of you who doesnt know.
My car is not an FTO...Its a lancer with FTO Mivec engine transplant :)
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
RichardH
Post by RichardH »
> "Stock Engine, Modified Driver" Life begins above 5000RPM
I guess you've gotta change that sig now, eh? ;)
- Rich
barfy
Post by barfy »
Ohhh now you tell us hahaha
Black_FTOGPX
Post by Black_FTOGPX »
FTO338 wrote:Now thats good stuff, well done. TB Magna here I come...heheehe
Same here, it should be a good cheap mod to do as well.
barfy
Post by barfy »
Hey i was just wondering if you did a lancer mivec conversion can u use the FTO Triptronic gear box ??
p13nox
Post by p13nox »
I have tried the bored out FTO TB and the machine shop ruined a perfectly good Throttle body, so I am now looking for a 65mm TB.
I've tried your breakers, if anyone can get hold of one and doesn't find posting one out to the UK I would be greatful!
:wink:
Will let you know p13nox..
Im on the hunt for a few, cause I have a feeling every FTO owner and their dog will be after one soon. I'll try and get as many as I can. Going wrecker shopping tomorrow - its been so long since Ive been to Blacktown!
Also found that the Magna TB's can also use a bit of work. Check this link:
http://neilk.customer.netspace.net.au/h ... rottle.htm
Although he's doing it to a TF Magna, I was speaking to a wrecker today & he said (with one of each in his hand - TR & TF) that they are very similar...
barfy wrote:Hey HRD2BQT
I am not HRD2BQT, but here it is:
HRD2BQT
Post by HRD2BQT »
Im pretty sure the tip box would offer just fine :)
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
barfy
Post by barfy »
Hrd,
Ive been thinking of getting a lancer and transplanting a Mivec engine into it, just wondering was it easy to do and how much it costed all up ?? Do you think i could get away with buying a manual lancer and putting in a mivec engine with tip gear box ?? Or would i have to start with a auto lancer ?
