Questions for those who had the UAS Cold Air Ramp Pod Kits
FTO338
Post by FTO338 »
I remember when I was looking at the UAS CAI kit, the intake pipe is fairly large compare to the original one.
So I was wondering, for those who got this kit with a big battery, (eg: 13-15 row or 4wd) do they have any problem? Do you have to relocate the battery or get a different size/type??
And if someone got a picture of their engine bay with these kit & a large size battery, which he or she can post up, it would be much appreciated.
Black_FTOGPX
Post by Black_FTOGPX »
I find even with my small battery the new pipe rubs against the battery mounts. (Only a little bit though)
I think if you had a large battery it may rub too much.
devil2004
Post by devil2004 »
the intake pipe is quite big. I've got a pretty small battery but the mounts still rub against the pipe. I'm pretty sure sooner or later the battery mount will chew a hole into my intake pipe. If you want a pic of the damage to my intake pipe caused by the battery mounts Kev then PM me with your Email.
Boris
Post by Boris »
same here, but you have seen mine already. :wink:
FTO338
Post by FTO338 »
Boris wrote:same here, but you have seen mine already. :wink:
Yeah thats why I asked here, as i'm thinking of getting a different CAI setup to mine, & I remember yours, & wonder how many ppl have the same problem & who had solve it.
But seems like even with a small battery its going to have the same problem. :(
Breza
Post by Breza »
I have what I assume is the standard battery (it can with the car when I got it a few years back).
The battery is skinnier? than the battery tray so I put the offending clamp in a vice and bent it so that it is positioned away from the UAS intake pipe.
I had problems with the pipe rubbing up against the hole in the box but assumed this was something to do with me using an APEXi pod rather than the UAS one. This was easily fixed by altering the angle of the APEXi brackets.
Was looking at moving the battery to the boot shortly (for a custom intake) but don't see any point when the existing battery seems to be working fine at the moment.
Cheers
Chris
barfy
Post by barfy »
Hey,
I found my intake pipe was rubbing so i went down to my local electrition and he actually cut the bracket shorter and then re welded it. So now there is a huge gap between the bracket and the intake pipe....
Ill trying and get some pics up .....
[img]http://i142.photobucket.com/albums/r103/barfy76/barfycopy1.jpg[/img]
FTO338
Post by FTO338 »
So does anyone got any soloution if you got a full size battery or a larger size one??
Camo
Post by Camo »
i have a 3 inch stainless steel intake pipe that just fits in touching my standard size battery (clamp has been removed)
Also if you are looking at doing a CAI box, have you thought about carbon fibre? its roughly $200 for the box etc and looks wikkid =D
Boris
Post by Boris »
Kev, i don't think the size of the battery matters, the actual bracket will still be there even if you have a small battery.
What i have done with mine is bent the bracket so it doesnt touch as much onto the pipe.
shue
Post by shue »
Camo wrote:i have a 3 inch stainless steel intake pipe that just fits in touching my standard size battery (clamp has been removed)
any pics of your cai? where did u get urs from?
Boris wrote:i don't think the size of the battery matters
Thats what all the chicks say... i don't believe 'em...
FTO338
Post by FTO338 »
Yeah this CF thing had been brought up before as mikey did a groupbuy not long ago. But i'm not looking at a box atm, as i said, i've already got a CAI setup with heat shield, but I like the idea of bigger pipe to match the new TB.
I'm running lots of electronic junks atm, so smaller battery isn't an option.
BuCkEt
Post by BuCkEt »
I'll post up a photo of mine when I finish work Kev....as my battery is decently sized.
Camo
Post by Camo »
i havent got the CF box yet, but i am planning to soon.
its from a guy that makes all sorts of CF stuff, quality stuff!
btw he is also trying to perfect atm CF covering, so instead of replacing the panel, you just cover it in a layer of CF. Obviously not a weight reduction, but its for the looks. First person in Australia to do it =)
(although i would never get this done)
you dont really need the battery clamp at all.... so that would give you some more room to play with =)
shue
Post by shue »
hey camo, want to get together and get a cf cai made with alum intake pipe sorta like the uas one. the looks on that one arent really appealing and yea cf box with alum pipe would look crazy. we can get someone who has a uas one to give us measurements :twisted:
EURO
Post by EURO »
shue - could be worth contacting mikey (GPX) he has a thread on CF products and airboxs were made at a good price from what I remember. Havent seen mikey online much lately but those ones have already been trialed etc etc...
FTO338
Post by FTO338 »
Camo i'll be interested if your mate can make a pipe out of CF, as i heard is pretty hard to do. And if that goes well, i'll get a CF box to match as well. :D
I think I posted mikey's one in the Tech section before, if not, it will be in the Groupbuy section.
Camo
Post by Camo »
shue, this guys CF boxes are trialed and tested, he has made them before for the FTO. its quality stuff!
as for the rest of the stuff u need - intake pipe and pod and piping etc its all easy to get/do.
you will be looking at around $400-500 for a quality setup that you can put together yourself or with the help of a friend.
let me know if you are interested and i can help you get the ball rolling or make some more detailed enquiries =D
Kev, i just spoke to him and he said that really it would be too expensive and a bit unrealistic to have a perfect pipe, but he might be able to do something similiar.
It would be a pipe made in 2 halves, each semi-circle would have a flat bit coming off the side so that you could bolt the 2 sides of the pipe together (if that makes sense to you ;p )
shue
Post by shue »
EURO wrote:shue - could be worth contacting mikey (GPX) he has a thread on CF products and airboxs were made at a good price from what I remember. Havent seen mikey online much lately but those ones have already been trialed etc etc...
the same guy who had the cf group buy for the radiator shield? i did send him a pm today.
camo 400 for the whole set up sounds good.does that include air filter 8) ?
