Can anyone enlighten me on the difference between the both?
cheers
Difference between a GPX and GR
- mcdare
- BuCkEt
GPX = MIVEC FTO
GR = Non MIVEC FTO.
MIVEC is a cam and valve changing process that occurs at ~5500RPM and is very similar to Honda's VTECH and Toyota's VVTi.
The GPX has 200BHP in factory form while the GR is slightly less, however (as some people here can atest to) there are some freak GR's out there that haul some serious butt.
Easiest way to tell the difference is to pop the bonnet and if the oil cap is on the left then it's a GPX.
GR = Non MIVEC FTO.
- BuCkEt
Off the top of my head I can only remember a few differences.
The air intake tube has the MAF sensor just behind the filter box on the GR.
The GR's brakes are slightly different as well, something to do with the size of the front caliper I beleive.
The extractors and exhaust are also different in regards to fitting of aftermarket equipment.
If you spend a bit of time browsing through the technical section I'm sure you'll find out plenty of information.
