Engine mounts
Engine mounts
It appears that one of the noises originating from the front of my car (squeak when press brakes) is due to the rear engine mount.
Anyone got any suggestions on the best place to source one of these. Part number would also be great
Ok, you got a couple:
This is the one I think you mean - Rear Nth-Sth Beam Mount - MR223874
This is the other one on the beam - Front Nth-Sth Beam Mount - MR131296
Then there are the 2 that live on either side of the motor:
Engine / Transmission Mount (Left) - MR197616
Engine Mount (Right) - MR197551
If u wanna get fancy, UAS do polyurethane ones...
They are about $200 a pop - exchange
http://www.uniqueautosports.com.au/
Hope that helps,
Cheers,
Ben.
