Power Window Problems...
NorthQLDFTO
Post by NorthQLDFTO »
Righto... I've just started having problems with the passenger side power window! Well, actually it's the switch on the drivers side that has issues cause if I use the switch on the passengers side the window operates without a hitch...
Clearly I need to fix the switch on the drivers side but what I want to know is if I can fix it so that like the drivers window I can push down on the switch once & the window will go all the way down/up without having to hold it?
I'd like to rig the passengers switch to do the same as well...
Any ideas as to what I need to do this?
If I Had A Dollar For Every Time Someone Said "If I Had A Dollar For Every Time Someone Said <...>" Well... Then... I'd... Have A Dollar For Every Time Somone Said "If I Had A Dollar For Every Time Someone Said <...>"!!!
check wiring first, could b loose
NorthQLDFTO
Yeah I figured it could be that... But I still want to rig it so that the windows go all the way up/down with just one press!
buy the 2 stage switch?
NorthQLDFTO
Well... Yeah... Of course... That's the obvious solution... :lol: Ha Ha! Like I hadn't thought of THAT already...
:oops: What's the Stage 2 switch?
BuCkEt
Post by BuCkEt »
If you notice with the drivers switch you can either push it lightly and control the placing of the window or you can just nail it and have the window go the whole 9 yards.
Just build the passenger switch to do the same, become a two stage switch.
And no, I have no idea how to do that.
Go buy a drivers side window switch & adapt it to fit in the passenger door & wire up as per the old one :)
NorthQLDFTO
:D Cool... Sounds relatively easy... Hee hee! I'll try anything twice!
Now, best place to buy a Stage 2 Power Window switch?
$10.00 Says Kempy's gets a mention :P
NorthQLDFTO wrote:$10.00 Says Kempy's gets a mention :P
lol I was gonna say wrecker..
