stalling
GENEGENE
stalling
Post by GENEGENE »
for the past few days whenever im slowing down or put my tip fto on neautral while slowing down...the car stalls occasionally and i also see that the car idles at very low rpm's..200-300 rpm's?
any help guys?
scarecrow
Post by scarecrow »
Yep, step a) reset the system! Disconnect the battery for a few hours, overnight is best. When you start the car up it may idle funny for a day but after that it could resolve the issue (ie. start idling back up at 500-700rpm).
If this doesn't work then you'll need to replace the idle stepper motor. Someone will link you to the relevant sites.
GENEGENE
Post by GENEGENE »
i guess mines the same problem?im in WA...where do i go to buy a new stepper motor?
Ebay
Ebay has em
http://cgi.ebay.com/MITS-FTO-VR4-IDLE-C ... dZViewItem
But you may be able to find cheaper elsewhere???
    minh
    Post by minh »
    Resetting ECU does Squat all when its the stepper motor.
    Guys you dont have to buy a "FTO" stepper motor at all. You ask for a quote and they hear FTO they will break your bank.
    Magnas, Pajeros, GSR etc all share the same stepper!!!!. LAter models work too and are abit slimmer and have a black backing instead of that ugly brown. Mitsu was smart as they shared teh same parts bin for this one. So go to the wreckers and get one.!!!! take your old one to compare.
    How do I know this? Cause i been through it!!!
    And yes stalling is most likely your stepper motor playing up. Before you put on your new one. Just clean the throttle and the new stepper with carbie cleaner until they are totally clean so they shut properly.
    scarecrow
    Post by scarecrow »
    Minh i've had the above stalling problem once before, just happned out of the blue one day, car would stall at sets of lights. Disconnected the battery for a bit then it was right as rain. The ECU needs to relearn the position of idle.
    minh
    Post by minh »
    scarecrow wrote:Minh i've had the above stalling problem once before, just happned out of the blue one day, car would stall at sets of lights. Disconnected the battery for a bit then it was right as rain. The ECU needs to relearn the position of idle.
    Yeah I understand where your coming from but for a good stepper idle motor you shouldnt have to do that. As the idle stepper runs out of step naturally the ecu needs to relearn the wear and tear of it.
    And instead of leaving the battery disconnected you can always pump the brakes a few times and that will discharge system too.
